Post by aeroxbud on May 9, 2021 6:10:41 GMT -5
That sucks. Only 50cc Yamaha we have here, all have the three bolt design.
Post by rocketbooster on May 12, 2021 6:02:13 GMT -5
Today few packs has come to me. I start bulid engine for client so I think it will be intresting to show you. Set up is quite nice stage6 sport pro mk2 doppler race crank stage6 mk2 bigvalve dellorto phbg 21mm Yasuni C16 pipe Full OverRange Malossi I not decided yet about clutch, bell and gearing. Maybe somone of you know tested set of gears that will give range of 100km/h For my build i have order new steering set, adapter and steering bar. So it will be naked I will upload fotos later.
Post by boosterocket on May 12, 2021 13:37:05 GMT -5
Post by rocketbooster on May 18, 2021 11:29:28 GMT -5
Post by hippo008 on May 18, 2021 14:02:16 GMT -5
The sleek, dazzling veneer of the 1980s. Love the Prebugs.
Post by rocketbooster on May 28, 2021 13:16:45 GMT -5
Post by geoffh on May 28, 2021 14:48:02 GMT -5
It looks very smart,nice work.I used some of that blue silicon fuel pipe it only lasted 3months keep an eye on it.
Post by rocketbooster on May 28, 2021 16:07:23 GMT -5
Thx for tip, this is first time that I used sylikon hose for gas. There is lot of work to do, before it will be on streets.
Post by aeroxbud on May 28, 2021 16:19:52 GMT -5
Looks good. Also looks loud. 😉
Post by rocketbooster on May 28, 2021 19:16:36 GMT -5
Looks good. Also looks loud. 😉 loud is fast 😂
Post by rocketbooster on Jan 8, 2022 12:57:49 GMT -5
Hi It was a long time since last time i did update on scoot. I do few things to it like, powder coat the wheels in nice gold tone, I have ordered koso DB-02r tacho, stage6 ssp switcher, brand new michelin power pure sc. As soon as i get ordered parts I will start to do major update and finish all work under the fairings
Post by aeroxbud on Jan 8, 2022 13:48:42 GMT -5
Wheels came out nice. You will like the Michelin tyres. What size did you go for, as normally the booster has a higher section side wall?
Post by rocketbooster on Jan 9, 2022 5:50:27 GMT -5
I have ordered 120/70/12 front and rear, found them in good price for both tires 75$ Most excited I am for this koso tacho witch has under plug temp adapter and i don’t have to run any other tacho.
Post by rocketbooster on Jan 15, 2022 10:49:35 GMT -5
Tires showed up, i changed one from 120 to 130 i think it will be better that way
Post by rocketbooster on Jan 20, 2022 13:07:52 GMT -5
More parts for MBK OEM set of ignition switch and I don’t know how to call it haha also previously mentioned s6 swicher. Set of new bearing for front wheel. I need your help, I want to change dust seal in front wheel. I don’t want to use OEM part beacuse is way chiper to use standard seal like on a crank, will it work as good as OEM?
