Post by markopollo on May 24, 2021 15:00:17 GMT -5
I've been using amsoil for a while now, seems like it's good for light duty stuff, what's your guys go to for firearm cleaners?
Post by geoffh on May 24, 2021 15:28:26 GMT -5
That's a casual question and could only come from the USA :)here in the UK firearms are normally a small brush a set of tongs and a shovel all tastefully kept on a rack by the actual fire,somebody post a picture for me please.
Post by Deleted on May 24, 2021 20:17:19 GMT -5
Hoppes #9 and Rem Oil. I find #9 helps with lead or copper fouling.
Post by woodini on May 24, 2021 23:24:57 GMT -5
I use the oil that daisy provided with my red Ryder bb gun
Post by FrankenMech on May 25, 2021 0:26:54 GMT -5
Air tool oil.
Post by jackrides on May 25, 2021 9:55:45 GMT -5
For rifles Hoppe's#9. If badly fouled, start with copper or brass brush, rinse repeat till clean pad comes out clean. Always start from the loading end.
Post by jbjhillbilly on May 25, 2021 21:36:54 GMT -5
MP7 for cleaning. Slip2000 or CLP for lubrication depending on the application. CLP applied lightly on blued metal, and the final patch down the bore. Slip 2000 on moving parts because it won’t gum up like oil will.
If stored longer term, I’ll keep them in a silicone sock (you know what they are). Make sure your safe has a heater rod in it to keep the temp from fluctuating - that’s how moisture gets drawn in.
That said, I don’t clean as obsessively as I used to. There’s a couple of guns that need to be squeaky clean to work (finicky bastards), but most don’t give a damn and do what they’re supposed to.
Cars drive, guns go bang. Or they get sold. The only reason to keep them around is sentimental value.
Post by scooterpimp on May 26, 2021 11:26:13 GMT -5
CLP for general cleaning / lube , Mobil 1 for the slides etc.
