Post by rjwittmann on Sept 25, 2021 8:06:55 GMT -5
Post by Zino on Sept 25, 2021 9:16:27 GMT -5
Did that pipe bolt right up on the mounting bracket . Or did you have to use a dremel to extend holes or drill new holes .
If you could give a close up of the mounting bracket it could really help the next guy .
Post by rjwittmann on Sept 25, 2021 9:30:46 GMT -5
So I cut the stock pipe bracket off and mounted the Polini pipe to the stock bracket. Worked out perfectly.
Post by hippo008 on Sept 26, 2021 15:08:00 GMT -5
May I recommend street tires? I swapped street tires onto my Roughhouse and I saw a huge benefit.
