Post by kinhekan76 on Feb 1, 2022 18:29:32 GMT -5
Is there another way to connect lithium ion cells besides spot wielding them. Is soldering sufficient.
Post by jbjhillbilly on Feb 6, 2022 13:39:29 GMT -5
Spot welding is probably faster for manufacturing, and reduces the chance of a break due to vibration, but I would think solder should be ok. Higher temp solder would be better, and maybe leave a little slack in your wires.
Post by ghostaroni on Mar 8, 2022 1:25:05 GMT -5
Is there another way to connect lithium ion cells besides spot wielding them. Is soldering sufficient. You will explode cells if you try to solder them. Get a battery tab welder...theyre 50 bucks..
