Post by peacemaker on Oct 25, 2022 9:17:00 GMT -5
I want those titanium exhausts.
Post by hippo008 on Feb 10, 2023 18:17:53 GMT -5
The weather is slated to warm up this weekend and Ive got the bug to get some work done.
Im a tinkerer by nature and I am constantly messing with my setups. The result is that none of my scoots are ever running for very long and none of them stay in a state of High-tune. With the surprise warm weather I would have liked to take something out for a ride but thats not possible given the my perpensity to tinker. Right before the end of the season I decided to finally settle on an engine setup for the Baja. The goal is a highly reliable and easy to tune setup I can ride everyday. I wanted to use the most reliable and highest end parts I could muster.
The goal setup is as follows. I bought all the parts already outside whatever carb setup I decide on.
Malossi Cast 70cc cylinder Malossi MHR Crankshaft Stage6 intake manifold 28mm SmartCarb (maybe). I will need a different needle from SmartCarb Malossi reinforced small end bearing New steel cage crank bearings Red Mole pipe JISO variator 98mm JISO drive face JISO belt TFS clutch bell Polini 4race adjustable clutch 16/42 gear up kit
Let me know what you guys think!
em781
Scoot Junior
Post by em781 on Jan 3, 2024 2:13:08 GMT -5
WARNING - THIS POST CONTAINS NSFW SCOOTER GORE! THOSE WITH WEAK CONSITITUTIONS SHOULD TURN AWAY NOW! I tore down the AF18 from the Baja, nice clean engine. It's always a pleasure to work on these Honda motors. I heated up the case halves to install the new bearings. The large side came together no problem. The small half was a wild ride, when I tapped in the bearing I heard a POP and this fucking happened. So now I need another set of AF18 cases. Paging all Honda guys, anybody want to sell me a Honda motor?!
em781
Scoot Junior
Post by em781 on Jan 3, 2024 2:15:25 GMT -5
If you still are looking for af18 case message me
