Post by avinogood on Apr 7, 2022 12:57:14 GMT -5
For some odd reason it wouldn't let me log in with the username I created a few days ago. Name is Shelby,, a 38 yr old male from the midwest. Recently acquired a 2004 vino 2T for $450. Ignorance, I am assuming, led to a e3 sparkplug being installed so I got that switched back to a factory NGK. I was wondering why it would randomly miss at idle, and eventually die with hard restarts. I try to run ethanol free fuel through her, Lucas no smoke oil, and a little marvel mystery oil in the fuel tank. Plans are as it's a running project, is tires, ignition (stolen from PO) gas cap, variator weights, small exhaust, just some good fun. Needs a rear wheel as the current one is bent to hell, the front one is perfect, which I don't understand.. Crazy quirks are why did they offer those horrendous turn signals and cargo rack, unlike the JDM models, lol. And last but not least it's factory tire, like the jog, is 80/90-10 90/90-10 should be no issue?
Post by aeroxbud on Apr 7, 2022 14:47:46 GMT -5
Welcome to the forum
Post by geoffh on Apr 7, 2022 14:50:30 GMT -5
Shelby,welcome to the form,only change one component at a time Geoff
Post by Zino on Apr 7, 2022 18:57:07 GMT -5
welcome to the forum You can go up a size on the back tire . The front tire you are stuck with the larger one rubs . The vinos are easy to make fast they need better suspension and brakes . I have a matching pair in my garage here is a link to my build thread 49ccscoot.proboards.com/thread/26756/yamaha-vinos-stealthy-build
Post by oldgeek on Apr 7, 2022 19:20:18 GMT -5
The 2T Vinos are a blast! If you are interested, I got a rear wheel you can have for shipping cost. It's kinda rusty but straight. I dug up some old pictures of it, I have since cut the tire off of the wheel.
Post by hellish100 on Apr 8, 2022 21:40:46 GMT -5
Welcome, Shelby! Hey oldgeek, if Shelby doesn't take the rear wheel, I might want to take it off your hands. I'll have to check my inventory to make sure it'll fit a spare 1pe40QMB I have laying around.
