Post by drumstyx on Apr 20, 2022 10:13:23 GMT -5
another silly question!
What are you Zuma folks running for belt lengths? The OEM belt that came in this thing was the listed-spec 738mm, but seeing that I was nowhere near the outside of the rear pulley, I put an Athena 751-16.5 on it...I'm still a good 4.5mm from the outside of the rear...
I'm watching those homemade overrange variator videos on youtube, and I notice that his Minarelli "clone" engines are using 788 belts, which I see are stock for the 4 stroke Zumas.
I ran a fabric tape measure around the belt as-installed, to verify its length at 751 -- yep, that's legit. I've got it shimmed pretty well perfect so the belt is just about touching the variator boss, so I ran the tape measure along the belt at the front, but around the outside of the rear pulley, and came up with 765mm, which is stock on some Peugeot scooters apparently. Unfortunately, I can't seem to find a North American supplier of these belts, since I don't think we've ever had Peugeots in North America.
One thing to note: this belt is 8.1mm thick, so while I don't mind a thicker belt, if my math is right, I'd need an extra ~3mm in length per 1mm extra thickness.
How the heck is 49ccscoot running a 788 on a Minarelli? I guess our engines ARE different though, since my CVT cover doesn't have a support bearing.
Any ideas for a good belt length here?
Post by ryan_ott on Apr 20, 2022 10:21:25 GMT -5
Post by drumstyx on Apr 20, 2022 11:15:50 GMT -5
OOOOO yes this is a great read, thank you! I see you're the OP on that one -- you mentioned a 764mm belt for an Aerox, but I can't seem to find that (at my canadian vendor at least). Got a link? Part number even? Any vendor that'll ship to Canada would work, just that North America is better on shipping
Post by benji on Apr 20, 2022 15:23:13 GMT -5
another silly question! How the heck is 49ccscoot running a 788 on a Minarelli? there are several motors minarellis made, including 3 (at least) different versions for Yamaha/MBK. Jog style is considered a short block, and runs a longer belt due to the final drive configuration. Just be glad you don't have an Eton.
Post by ryan_ott on Apr 20, 2022 21:20:58 GMT -5
Post by Zino on Apr 20, 2022 21:42:59 GMT -5
With the polini variator and malossi variator . I actually got to 2mm left with a stock belt . The right size shims and just the right weight of weights . With a street pipe or Stock pipe I was 6 grams with the polini and above to get the travel. With the expansion pipe tecnigas next r and yasuni r I was between 5 and 6 grams . Manufactures measure belts difference I prefer to roll them out Here is a thread where we discuss belt lengths 49ccscoot.proboards.com/thread/28919/malossi-belt-size-verification
Post by nickatnight on Jan 19, 2024 15:41:51 GMT -5
another silly question! How the heck is 49ccscoot running a 788 on a Minarelli? there are several motors minarellis made, including 3 (at least) different versions for Yamaha/MBK. Jog style is considered a short block, and runs a longer belt due to the final drive configuration. Just be glad you don't have an Eton. quick question, why should he be glad he doesnt have an eton? sincerly an eton owner
