Post by NathanielS on Jul 21, 2022 13:41:17 GMT -5
I have a 1988 Yamaha razz sh50, hoping to use it for the rest of high school and then sell. The body panels are in bad shape… I picked it up for free and the previous was in multiple small crashes. What should I use to fix the cracks that is cheap and will stay?
Post by NathanielS on Jul 21, 2022 13:48:41 GMT -5
Post by aeroxbud on Jul 21, 2022 14:35:47 GMT -5
It you have a soldering iron, you could try plastic welding them. Quite a few tutorials on YouTube.
Post by NathanielS on Jul 22, 2022 13:03:54 GMT -5
I do... I'll look into it. Thanks for the help!
Post by jbjhillbilly on Jul 23, 2022 14:19:46 GMT -5
You can also use ABS pipe cement to help reinforce the welds.
Post by FrankenMech on Jul 23, 2022 18:15:35 GMT -5
You can also use ABS pipe cement to help reinforce the welds. -And some ABS sheet which can be found at hardware stores.
Cracks can also be reinforced with fiberglass cloth and resin, available at hardware and auto supply stores.
I have also seen people use formed metal plates and pop-rivets, which does not look very nice.
Some people have even cultivated the 'naked' bike look without most plastic panels or just a minimum.
