Post by behrnt on Aug 30, 2022 9:13:52 GMT -5
hello everyone I am a scooter newbie I bought my 2003 Honda metropolitan 2 yesterday. i’ve been having problems with the acceleration and top speed I feel like I barely accelerate and I top out around 25 if I have a long stretch then I get closer to 30 but nothing more. any ideas?
Post by FrankenMech on Aug 30, 2022 11:41:15 GMT -5
Tell us more about your scoot. What engine size does it have? If it is a 50cc that seems pretty normal for performance but you may be able to help it a little.
Post by jbjhillbilly on Aug 30, 2022 12:53:08 GMT -5
Welcome!
The Met and the Met 2 are very different scoots.
The Met 2 is specifically made for a “moped” designation for states that have one. That means lower horsepower, and severely restricted speeds.
The carb has a different needle, and diaphragm spring. The variator is restricted, the intake is slightly different, the ECU is rev limited, and the cam is different as well. I seem to remember it using Ruckus gears as well, that when paired with the Met’s smaller tire, keeps speeds low.
You can overcome all of this (the cam probably isn’t worth splitting the case for). A standard OEM carb, intake, and variator are easy enough. If you swap the ECU, you’ll need a matching rear electrical harness.
You can probably grab a slightly used 2006-2009 Metro GET motor for not too much money and swap it out. If you find a Ruckus motor, you have to change out the swingarm from your Met.
Post by behrnt on Aug 31, 2022 8:35:33 GMT -5
yes it is a 50 cc but going downhills I can steal the engine slow down the scooter to stay at 29. I was just hoping there’s something I can do to increase top speed
Post by FrankenMech on Aug 31, 2022 11:43:33 GMT -5
Welcome! The Met and the Met 2 are very different scoots. The Met 2 is specifically made for a “moped” designation for states that have one. That means lower horsepower, and severely restricted speeds. The carb has a different needle, and diaphragm spring. The variator is restricted, the intake is slightly different, the ECU is rev limited, and the cam is different as well. I seem to remember it using Ruckus gears as well, that when paired with the Met’s smaller tire, keeps speeds low. You can overcome all of this (the cam probably isn’t worth splitting the case for). A standard OEM carb, intake, and variator are easy enough. If you swap the ECU, you’ll need a matching rear electrical harness. You can probably grab a slightly used 2006-2009 Metro GET motor for not too much money and swap it out. If you find a Ruckus motor, you have to change out the swingarm from your Met. I think this is a pretty good list.
Post by jbjhillbilly on Sept 1, 2022 17:29:00 GMT -5
yes it is a 50 cc but going downhills I can steal the engine slow down the scooter to stay at 29. I was just hoping there’s something I can do to increase top speed Right now, it can’t go faster because of all the restrictions. You can take every single one of them off. It might seem daunting, but with the exception of the variator, it’s all done with a Phillips head screwdriver, and 10mm socket. The variator is just a bit trickier, and it helps to have an impact wrench.
Post by stretch74666 on Sept 5, 2022 18:14:07 GMT -5
I have a baccio VX50 2 stroke it was driving nice Till I just put the 70 cc kit and now he won’t run right so I need a bigger jet I’m kinda of a newbie at this my engine is a 1pe
Post by Zino on Sept 5, 2022 19:44:55 GMT -5
yes it is a 50 cc but going downhills I can steal the engine slow down the scooter to stay at 29. I was just hoping there’s something I can do to increase top speed That is the rev limiter it will not let the engine rev beyond a certain rpm so you can trick it by increasing gear ratio by changing the variator or getting taller tires one size larger this will get you higher speed at same rpms Jhbilly gave you a pretty good list of next steps after that carb and intake could be upgraded so you breathe better and can support higher rpms the ecu swapped out so you can rev higher . Whats your budget ?
Post by Zino on Sept 5, 2022 19:46:30 GMT -5
I have a baccio VX50 2 stroke it was driving nice Till I just put the 70 cc kit and now he won’t run right so I need a bigger jet I’m kinda of a newbie at this my engine is a 1pe Stretch start your own build thread so we can advise you on your particular engine a 70cc 2 stroke is a whole different animal than a 50 cc 4 stroke
Post by behrnt on Sept 18, 2022 21:09:57 GMT -5
UPDATE:
I got the nyc performance cdi box and i installed it i gained decent acceleration but not much too speed i am currently thinking about upgrading the cam exhaust and intake. i don’t know if i should get a new carb though when i got it it had been replaced
Post by jbjhillbilly on Sept 20, 2022 17:20:53 GMT -5
UPDATE: I got the nyc performance cdi box and i installed it i gained decent acceleration but not much too speed i am currently thinking about upgrading the cam exhaust and intake. i don’t know if i should get a new carb though when i got it it had been replaced Start with what you have, but you might need to upjet. Scooter Swap Shop has a replacement carb that’s tuned toward the GET engine.
