Post by Deleted on Dec 8, 2011 16:32:29 GMT -5
My father loves the color so i sold it to him. We are going to put a 50mm kit on it and a windshield. It got so hot the bit of the base gasket that is sticking out from the cylinder is now black and crispy
slawenm
Post by slawenm on Dec 8, 2011 17:32:54 GMT -5
thats good, hope it all goes well!
Post by Deleted on Dec 30, 2011 17:27:07 GMT -5
this is what no fan shrouds will do for ya.... that chunk is not a piece of ring its part of the piston...from between the compression ring grooves. The other little piece came off the piston when pushing the pin out with a big clamp and 2 sockets because the piston was expanded around it... ..And whats left of the burnt base gasket.
Post by Deleted on Dec 30, 2011 17:41:42 GMT -5
New 50mm top end and a shroud set from PFS..gonna finish it up tomorrow
Post by 90GTVert on Dec 30, 2011 19:43:41 GMT -5
Not sure why so many people think it's a great idea to ditch the cooling stuff, but glad you're getting it back together and right.
Post by jmkjr72 on Dec 30, 2011 21:34:33 GMT -5
Not sure why so many people think it's a great idea to ditch the cooling stuff, but glad you're getting it back together and right. yeah that baffels the hell out of me too if i dont see the hey can i just ditch this plastic question once a month i am suprised i guess people think that the companies like to waste money on parts that arent needed in there eyes i can see big companies maybe going the extra yard but come on even the cheapest of the cheap bikes have them and there called force air cooled engines for a reason but then again its just like all the guys that think getting rid of the shroud on the rad in cage is a good idea too
Post by Deleted on Feb 18, 2012 13:24:22 GMT -5
Yellow Fever has had a makeover. Medium case Quinqi (Chinese Suzuki) motor with 5 spoke 12" wheel Rear fender delete 50mm 82cc bbk 18mm Kehin PD18J carb jetted 95/33 w/needle raised full UNI 2 stage filter Pref cam Orange coil and cdi Irridium plug 5.5g Dr Pulley sliders with stock contra Bando belt P&P pipe and muffler Prima magnetic drain plugs LED signal lighting front and rear Windshield
vvtr
Post by vvtr on Feb 18, 2012 14:56:15 GMT -5
looks pimp - well done
Post by 90GTVert on Feb 18, 2012 16:14:24 GMT -5
Looks really good from the back now. To me, the addition of a sporty wheel/tire combo, a pipe, and a delete/clean-up back there is so much better looking than all those stretch kits with golf cart wheels and such that most seem to like.
Post by Deleted on Feb 18, 2012 16:49:29 GMT -5
Post #18 up there i didnt check the gaps on the oil rings and of course they were too wide and it smoked like hell It was then i decided to build up this motor. Its the motor I had originally bought for Stroker 95. It has the keyway on the flywheel in the wrong place so when you line the marks up its a tooth off. Might be why I got it so cheap ($100) I think the guy couldnt make it run because of that. Runs good now
Post by Deleted on Feb 18, 2012 19:06:34 GMT -5
Future plans are front disc brake conversion w/5 spoke aluminum wheel and larger tire for the rear. @1"drop front @2" rear.
Post by ninjascoot on Feb 18, 2012 20:37:27 GMT -5
I like the looks of that yellow, it has the same body as mine and now i want to remove some of the crap over the rear tire.
Tweak09
2011 Yamaha Zuma
Post by Tweak09 on Feb 18, 2012 23:50:16 GMT -5
Back end looks nice man. Well done! :clap:
Post by Deleted on Feb 19, 2012 7:59:25 GMT -5
You all might find this interesting.....those off brand orange cdi boxes, they do have a rev limiter.
Post by 90GTVert on Feb 19, 2012 9:07:23 GMT -5
Any idea what RPM it's at? I know some aftermarket CDIs are said to be limited at 10,000RPM. For most 4T builds that would actually be kind of a good thing.
