bettah135
New custom 180cc stunt bike on the WAY!!!
Post by bettah135 on Oct 17, 2022 19:33:31 GMT -5
bettah135
Post by bettah135 on Oct 17, 2022 19:34:01 GMT -5
bettah135
Post by bettah135 on Oct 17, 2022 19:44:48 GMT -5
I’m rebuilding a 150cc but I’m leaving all the plastics off and just repainting the frame. Converting it into a stunt bike!!! I’m aiming to replace all the following STATOR STARTER ENGINE FROM END TO TOP (cylinder & valve head) But I’m having trouble finding the correct WIRE HARNESS!!! It put my build on pause !!! Do any of you kind gentlemen know the correct name/ place or one to order ?? All the ones on AMAZON seem to be for ATV’s. Will these work correctly?? I’ve heard as long as the STATOR PLUG MATCH it could be used , is that true??
Post by jbjhillbilly on Oct 18, 2022 23:03:25 GMT -5
Knowing which scooter it is will help.
Post by repherence2 on Oct 19, 2022 16:07:13 GMT -5
from what i see in your pictures, from the way your engine mount looks, it appears to me that you could mount a Minarelli, Chinarelli, or a Polaris ATV engine on that bike.
as far as your question about wire harnesses, make sure you check what type of CDI plug you have on your existing harness. i am a 2 stroke guy so i basically only know "JOG" (yamaha) or "DIO" (honda). they have different CDI pin outs. one is a "5 pin" and the other is a "6 pin".
bettah135
Post by bettah135 on Oct 21, 2022 12:42:57 GMT -5
It’s a 6 pin CDI
So a harness with 6 pin CDI would work???
Post by dexameth on Nov 4, 2022 18:11:46 GMT -5
Yo, so here's a wire harness that'll be awfully close to your setup... but you may need to change connectors here n there to make everything work. Luckily, Chinese scooters all use basically the same wire colors for each function so splicing in isn't too difficult. Click Here for Wiring HarnessThis harness is for AC CDI. The DC CDI wiring harness has a different kill switch function and CDI connector and wiring is different. Verify your scooter is AC before snagging this one up.
