Post by Zino on Dec 2, 2022 18:31:56 GMT -5
What size rims do you have on there. I have a new back tire for you if you have the 12 inch rim .
Post by RH50Wisco on Dec 2, 2022 19:11:19 GMT -5
I have the stock for 2015, so the 10s.
Post by wiscootsin on Dec 6, 2022 22:36:59 GMT -5
i'm guessing you're in the general madison area? if so, you can probably pickup a roughhouse at a local salvage yard if you didnt want to repair bent forks,etc. students abandon these. I picked up one that was previously owned by a star running back. lol
Post by RH50Wisco on Dec 7, 2022 9:40:44 GMT -5
Yes, I have thought about going that route if I had to. I am pretty far along on this restore now and I'm not sure any of those units would be in much better shape, but thanks for the suggestion. This bike I am restoring has been owned by 3 different Badger football players. The original owner now playing for the Raiders, the next owner just entered the portal, and the third/final is some local talent that recently graduated.
Post by RH50Wisco on Dec 15, 2022 14:37:39 GMT -5
Post by RH50Wisco on Dec 27, 2022 10:14:28 GMT -5
Roughhouse Dellorto 19mm racing carb initial set up:
I got her fired up for the first time this weekend. Had to tweak the idle speed screw just a bit to get it to run. It sounds really good, and really loud (didn't have the silencer on yet). It had really smooth throttle all the way through the range.
My Dellorto clone racing carb came with the following: 72 main W16 needle 50 Slide Choke/Starter Jet - 60 Idle Jet - 48
I changed it to the following for initial starting point:
Main = 96 W7 needle in slot 3 of 4 (on the richer end). Removed a bushing that was between the atomizer and main jet.
Without the silencer installed on exhaust it had really smooth and responsive throttle. After putting on the silencer I get a bog at early throttle, so now the tuning fun can begin. I will assume that adding silencer is putting more back pressure on exhaust which would cause a rich condition which is right where I want to be for a starting point. Now I just need to wait for the weather to improve a bit so I can do some road testing and final tuning.
I also have a few more things to put back together before taking on the road so I will tune as best I can on the stands while putting the rest back together, but getting really close at this point.
I have done nothing with the CVT yet so still have that to dig into before finalizing.
Post by RH50Wisco on Jan 3, 2023 18:02:48 GMT -5
Roughhouse horn switch: 1/4/2023: edit to fuse info below As I continued to work on putting the front dash/handlebar area back together I discovered the horn was not working. This seems to be a fairly common problem and not a lot of posts on it so thought I would document the Roughhouse system. Step 1 was to determine if horn was bad. For this I just ran a jumper wire from the battery positive to the terminal on the horn with the green/yellow wire. I was able to get it to beep with the hot jumper so on to the switch. The first thing I did here was use the multi-meter to see if I had juice at the green/yellow wire at the switch, and I did. This is the terminal on the right in this pic. Next I used a jumper wire to make connection between these two terminals, this resulted in a beep so definitely a problem somewhere below these two terminals. Next step was to take apart the switch to see what I could see. This is all held together by 4 screws, 3 you can see in the above pic, 1 other is kind of hidden under the wiring harness. I didn't see any obvious signs of corrosion or anything broken. In the pic below the red arrow points to the contact surface that the hot terminal on the other side of this plastic goes to. There is an insulator between that and the spring and base. All areas pointed to by the blue areas are what close the circuit and are connected to the left terminal from previous pic. This includes the spring, spring base (which is what the wire is soldered to), and contact point embedded in button. I didn't really know what to do at this point to get it working so I just took a needle nose pliers and twisted the spring a few times. Horn works again, so I assume the twisting removed some kind of corrosion crud between the spring on one of the bases it sits on. Now time to put it all back together again. Make sure to take note of the order the plastic pieces go together. The blinker switch will not work right if it isn't put back together properly, ask me how I know that. I took this apart and back together a few times before getting it right. You should put the high-low beam switch in first, then the tab for the blinker switch goes on top of that, then both mount points for the horn switch go on top of blinker switch. You can see all that in the below pic. Another word of advice...make sure you have extra fuses because good chance of blowing it a few times going through this troubleshooting. It takes a 15A/250V and is the shorter size. The regular size you get from the auto store is too long, but can work in a pinch for troubleshooting, but you can't close the case with longer one. You can buy a 5-pack of the auto size (longer) at auto store for about $4, or go on Amazon and get a 200 pack of various amps and sizes for $10 which will include the shorter length that is needed for this fuse holder. New edit: I received the 200 pack of fuses from Amazon and they do not fit, so those are going back. The short one is also thinner. Original fuse is 6mmx25mm, standard auto fuse is 6x32, standard short version is 5x20. The correct fuse is referred to as a size 8AG 15A/250V, and these are not so easy to find. For all the trouble I have decided to convert this inline fuse to a marine grade blade fuse. I think this will be a nice little upgrade. Going with this: www.amazon.com/gp/product/B08JZ5C29C/ www.amazon.com/gp/product/B08NSF2WXW/
Post by RH50Wisco on Jan 11, 2023 9:03:24 GMT -5
I am pretty pleased with how the new fuse turned out.
Post by RH50Wisco on Feb 28, 2023 14:05:35 GMT -5
Post by RH50Wisco on Feb 28, 2023 14:25:28 GMT -5
Currently working on LED conversion. Will be posting all the details on that soon.
Post by rollingbender on Feb 28, 2023 15:15:23 GMT -5
Your paint work looks fantastic!!!😎
Post by RH50Wisco on Mar 2, 2023 10:16:02 GMT -5
LED Conversion: I finished off this part of the project last night. My goal was to remove all the stock blinker units as I don't really care for the look. They hang out kind of far and are just waiting to be broken off (at least in the back). I found one of the Ducati integrated knock-off units on Amazon and then found some very sleek units for the front. www.amazon.com/gp/product/B00OYR46C8www.amazon.com/gp/product/B08V8BHLM4These front units can come as either blinker only or blinker/running light combo. I went with the blinker only since I knew there wouldn't be stock wiring there for the running lights. I did some test hookups just to make sure everything worked as expected before doing a more permanent install and immediately noticed that the blinky-blinky was extremely fast. Some research answered this pretty quickly. The LED blinkers don't provide enough resistance so the flasher goes too fast. To resolve this need to purchase these resistors. www.amazon.com/gp/product/B004EDF8HYWiring these is a bit strange, you tap one end into the positive and the other to the negative so it sits between the two leads that go to the blinker. I pulled the wire sleeve off the old blinker to reuse, then twisted the resister ends to each blinker end then capped off with new male bullet connector. In this pic you can see the new blinker leads coming out of the black wire sleeve and joining with the leads from the resistor which are the fatter red wires. Here is a comparison of the look: I have to say that the stock blinker is much brighter, but probably just due to the sheer size of the bulb. I still prefer the look of the LED better and there are probably other options that would work here if you really want a bigger/brighter LED. I have some short videos I took but will need to figure out how to post a video here. To mount the resistors I secured them to the handlebar via zip tie. There are all kinds of warnings that these things get extremely hot and not to mount them next to plastic. I did the best I could to keep them from resting on plastic but is a little hard to do. I'm not too concerned here as I don't think the very quick and limited use of the blinkers will produce much heat. Now on to the back. At first glance it seems like a direct replacement for fit and for the most part it is. The problem is this new unit has longer posts and are not threaded all the way to the base of the unit. This makes it so you can't tighten the nut on all the way for a snug fit. To resolve this I padded the posts with some rubber spacers I found. This was actually part of my broken center stand that will never be mounted to this bike again. I sliced it in half and used it on these posts. Now for the wiring. Here is the wiring for this aftermarket unit: Black (Ground) -> Black on bike. Stock wiring will have 3 grounds, 1 for each blinker and 1 for the brake light. You can use any one of these as this integrated unit only needs 1 ground). I used one of the blinkers just to save from splicing on another female bullet connector) White (Running light) -> Yellow on bike. I checked the wiring diagram for this one and this yellow wire goes all over the place on the bike. It is a very low-voltage line and only measures about .5 volts. Red (Brake on) -> Light blue on bike Blue (L-blinker) -> Pink on bike Yellow (R-blinker) -> Light brown on bike The stock blinker wiring already has the same size bullet connectors so those just plug right in. For wiring the brake you need to chop off the stock connector that has the 3 wires (Black, light blue, yellow), then put female bullet connectors on the yellow and light blue and just plug everything in. After this was done I spent the rest of the evening putting most of the bike back together and I will post those pics next.
Post by RH50Wisco on Mar 2, 2023 10:33:06 GMT -5
Post by RH50Wisco on Mar 2, 2023 11:34:18 GMT -5
This is a very quick attempt at posting some video of the LED lights. In the second video the last part of the clip is is slow-mo which is why it looks a little strobe-light like. I kept that in there because the clamp I was using to hold the brake lever on falls off so you can see the difference from brake on to just running light.
Post by jbjhillbilly on Mar 2, 2023 14:09:12 GMT -5
That looks so good! For sure a keeper after all the work you put into it.
