Post by rollingbender on Jan 18, 2023 1:30:07 GMT -5
My “transformation of a Chinese scooter” build is about to make a big leap by installing a short case 125cc GY6 crate motor. In order to weld the new engine hanger to the frame, I need the rear wheel to establish the centerline. Trouble is…. I cannot find a 10” rim. The 50cc rims have the proper splines and brake drum to fit my engine but the dish is wrong and the rim hits the case. A 50cc rim has about an inch between the edge of the brake drum to the left edge of the rim. I have established that this distance needs to be .3125 to have the rear wheel centered in the opening of the engine case.
So… I will make my own by modding a 50cc rim.
The rims I bought for the project have 16 curved spokes. I cannot easily duplicate these rims but hopefully what I end up with will at least match the design.
Here’s the rim we want to match…
And here’s the rim I’m going to modify…
I started by cutting out the spokes with a jigsaw. Wow, this Chinese aluminum is SOFT!!!
Then I removed the remains of the spokes from the hub and made it true by turning it on my lathe using an axle as a mandrel. So far, so good!
Now I need to remove the spoke remains and true up the outer ring of the rim. Not so easy. I clamped the rim to the bed of my CNC mill and used the machine to take a whole bunch of measurements but I could not find a spot where the rim was actually round. Blame it on the casting. I flipped it over and tried again and BOOM, round on the first try. I guess I’ll have to start from the back to true up the inside and then flip it back over to remove the last bits of the old spokes.
Next will be to cut out the new insert to go between the outer rim and the hub. I’ll cut this out of 3/4” aluminum plate on the CNC. I have it all drawn up and the code created to make the cuts. Here’s an animation of the cutting process
Now I just need to round up a piece of plate to cut it from. After the insert is made I will TIG weld the whole assembly together.
