kevino
https://www.youtube.com/watch?v=04dSGwAssRA
Post by kevino on Jun 19, 2023 8:30:44 GMT -5
kevino
Post by kevino on Jun 19, 2023 8:43:15 GMT -5
kevino
Post by kevino on Jun 19, 2023 8:49:21 GMT -5
A few more photos. The air filter is off the manifold and the manifold is off the intake. I believe the last photo shows my finger on the head of the cylinder. When I remove that I should be looking at the valves and tappets. Only problem was working bent over and needing a flashlight in one hand while wrenching with the other. At one point I needed both hands and held the flashlight with my teeth.
Post by aeroxbud on Jun 19, 2023 16:03:59 GMT -5
kevino
Post by kevino on Jun 20, 2023 12:48:22 GMT -5
...and remove the spark plug to make rotating the crankshaft easier.
kevino
Post by kevino on Jun 20, 2023 13:20:34 GMT -5
The problem now is there's two areas of plastic. One above and one below the cylinder.
kevino
Post by kevino on Jun 20, 2023 14:09:47 GMT -5
kevino
Post by kevino on Jun 20, 2023 14:14:49 GMT -5
Got the two pieces of plastic off the cylinder. Now there's a large cover on the left side and a smaller cover on the right side. I assume the left cover must come off to set TDC. Or is it the right cover? BTW, I dug out my old belt from my younger days working as a furniture mover. It makes bending over much less painful.
Post by aeroxbud on Jun 20, 2023 14:19:06 GMT -5
kevino
Post by kevino on Jun 20, 2023 16:08:37 GMT -5
I scanned aeroxbud's video. I guess I didn't need to remove the left side cover. I'll put the screws back in.
kevino
Post by kevino on Jun 21, 2023 10:14:44 GMT -5
