kevino
https://www.youtube.com/watch?v=04dSGwAssRA
Post by kevino on Jun 23, 2023 17:14:09 GMT -5
The string is a clever idea. I pushed a pin into the piston up to the groove then held it with my finger while jamming the clip into the groove. Same thing on the other side. Then rotated the clip to be sure it was trapped in the groove.
Thanks
kevin
Post by aeroxbud on Jun 24, 2023 3:39:05 GMT -5
There is definitely a knack to getting the circlips in. Once you've done a few it's not so bad. A good pair of pliers really help.
kevino
Post by kevino on Jun 24, 2023 6:55:11 GMT -5
Didn't help that I coated the piston with oil before trying to insert the circlip. :-)
kevino
Post by kevino on Jun 24, 2023 10:34:33 GMT -5
The removable chain guide can go in either up or down. One side has no paint so I assume that side rubs against the chain. I'm guessing. Any suggestions? Does it matter which way I choose to put it? TIA, kevin
kevino
Post by kevino on Jun 24, 2023 10:39:26 GMT -5
kevino
Post by kevino on Jun 24, 2023 10:44:53 GMT -5
The upper photo show the guide with the missing paint. I remove it and turn it over then replace it. The it shows an all-black guide.
Post by geoffh on Jun 24, 2023 14:35:24 GMT -5
Use the directory icon on the left of this page,GY6 top end rebuild to help with the guide.
kevino
Post by kevino on Jun 25, 2023 14:17:58 GMT -5
Thanks for the help. Today I got the rails and the cam in. Tomorrow the tensioner.
kevino
Post by kevino on Jun 26, 2023 10:16:48 GMT -5
At last something seems to be going right. I got the chain tensioner in. While it was still slightly loose I used an old feeler gauge. I jammed it back and forth into the gap hoping to trigger the spring to release. Whether it did or not I can't tell. The reasons for removing the engine are growing: I couldn't tighten the three bolts beyond finger strength.
kevino
Post by kevino on Jun 26, 2023 11:17:11 GMT -5
The rocker arm assemblies of an X on two corners diagonal. YES, I forgot to get a photo while it was still attached. An X on two corners and B on the third and am M on the fourth corner. There's a joke here somewhere about BM but you'd have to be in your 70's to get it. So how do I put the assembly back in? I realize I've got a 50/50 chanae of getting it right. More help please, TIA kevin
kevino
Post by kevino on Jun 26, 2023 12:07:54 GMT -5
After getting everything back in I found four metal tubes which I assume are important. So I have t tear everything down and start over.
kevino
Post by kevino on Jun 26, 2023 12:08:50 GMT -5
kevino
Post by kevino on Jun 26, 2023 14:31:37 GMT -5
I found an old drill just big enough to tap the bent tube into it. Them pulled it off by hand. That's as straight as I can get.
kevino
Post by kevino on Jun 26, 2023 14:40:11 GMT -5
I'm ready to pull the cam assembly off and put the four tubes in. I'm still hoping someone can tell me whether the can assembly is in right or backasswords. :-) kevin
Post by aeroxbud on Jun 26, 2023 15:14:10 GMT -5
The four metal tubes are dowel pins. Two locate into the cylinder to the block. And two locate into the cam assembly to cylinder. It will only line up one way.
