Post by fabster on Sept 9, 2023 12:49:42 GMT -5
Post by 808ministroke on Sept 15, 2023 17:29:53 GMT -5
Sorry I know this is not pertinent to your build but it seems as though the centerpiece in those twin cylinders was actually made up of 2 parts if this is correct or even if it's not could you please post any more pictures of that centerpiece you may have again sorry I know it's not related to your awesome build.
Post by fabster on Sept 16, 2023 21:27:58 GMT -5
No worries, this is entertaining. As long as we post awesome stuff, the thread title doesnt matter I went back in my archives and those were the best pictures of it. It's vague, I dont't remember :s Hard to believe it's been already 10 years since it went on sale ! www.scooter-system.fr/news/2111-bicylindre-bidalot.htmlwww.scooter-system.fr/news/2520-bicylindre-mxs.htmlAs for the Jog, I'm still currently building the V3, but want to start this thread with V1 to show you the complete build chronologically. I'll post more infos and pictures soon.
Post by 808ministroke on Sept 23, 2023 5:37:20 GMT -5
THANKS A BUNCH I'm taking notes...
Post by fabster on Jan 4, 2024 23:16:07 GMT -5
Post by fabster on Jan 9, 2024 13:09:14 GMT -5
Reception of a 10" rim and Pirelli Angel scooter tire First Mock-up
Post by fabster on Jan 10, 2024 11:00:35 GMT -5
On his 2 feet ! I'll be using the same Aerox radiator that my friend chose, with a new gloss black paint
Post by 808ministroke on Jan 12, 2024 4:40:08 GMT -5
I have the exact same radiator and one of my bikes mounted on the front outside of the panels I was using for A77CC I'm guessing that that radiator would not be sufficient for a 100 CC engine unless it was only for short drag races which maybe your whole purpose, That radiator would not be sufficient for A Daily driver of the same engine correct?
Post by fabster on Jan 14, 2024 10:49:11 GMT -5
I have the exact same radiator and one of my bikes mounted on the front outside of the panels I was using for A77CC I'm guessing that that radiator would not be sufficient for a 100 CC engine unless it was only for short drag races which maybe your whole purpose, That radiator would not be sufficient for A Daily driver of the same engine correct? With that kind of power, you're not WOT all the time. When riding normally, this is not really an issue. But the lack of airflow in traffic is. An electric fan help, but it requires quite a bit of power that we don't have with internal rotor ignition, in order to have enough CFM. That's why we went with big dual radiators on the street, and would not build any setup with less then that for safety. Drag race, you're right, the Aerox radiator is enough. But the smaller radiators from Gilera Runner are too small, even for that application. An RT70 was almost overheating with the latter.
Post by fabster on Jan 17, 2024 21:20:18 GMT -5
Opening for the Stage6 / R&D Italia admission kit My friend made a spacer for the 47mm crank on the Zuma engine. The existing spacer fits on european horizontal crankcase that have a different bolt pattern. We then did the opening for the cylinder skirts Stock vs 2Fast
Post by billwill on Jan 17, 2024 22:26:40 GMT -5
Clean! Did you do that by hand? What a drastic size difference.
Post by 808ministroke on Jan 19, 2024 22:17:44 GMT -5
Those are some really good pictures thank you for sharing those with me and everyone. I have been curious for quite some time about porting the intakes of minerally engine cases, And this is the first time I was able to see pictures of what exactly that would look like which gives me the confidence to do it myself In the picture it looks like in a spot the intake actually was opened up to the point where there was a opening in the case is this my imagination or did you have to JB weld or seal that some way after opening it? Yes please share with me the measurements that you open the intake 2 as well as what reads you are planning on using looking really good my friend!
Post by fabster on Jan 25, 2024 15:19:49 GMT -5
The intake track was on the milling, while doing the opening for the bigger crankshaft. Ports matching is by hand. After multiple setups over the years, I match the cylinder and remove very little material other then that. This is the intake, except that one is facing rear. I bought that one first, then when making the frame realized that I needed the front facing version. I still got this rear facing version for sale, if anyone needs a great intake setup This setup is different because the reedblock is clocked 90 degrees compared to an horizontal reeedblock. That's why there is a big hole in the crankcase. I used an Epoxy named Tech Steel to fill. The MXS intake is the other best intake for Mina Hori engines.
Post by fabster on Jan 25, 2024 15:25:02 GMT -5
Post by fabster on Feb 1, 2024 11:30:21 GMT -5
