Post by vvtr on Dec 30, 2011 20:51:03 GMT -5
hi chaps..
bought myself another scoot
this one's a '00 peugeot speedfight ac
looks a bit dazzling atm lol finished in a bright orange urban camo
mods so far include leo vinci pipe, polini 70cc kit with new piston & rings, bearings just done, stage 6 induction kit with 19mm carb, better cdi & coil etc, malossi multivar variator, malossi +10% gear kit, full circle crank and nice new sports profile tyres
fuelling's ok but it's not quite revving out as good as i'd like... so after a few miles under the belt i stripped the covers off & measured the squish for starters & found it at 2.1mm which imo is a little on the high side!
so anyway, as ive some experience in 2 stoke porting from my race days ive been checking out your port maps with interest and will be having a play with this software before i make any major changes... mediafire.com/?w8em1enwwtcwwx8
im looking for a nice midrange to top end peaking as high as possible.... 12 - 14k rpm if the can will allow it!
appreciate your wisdom on this and will keep you updated as to what i find & what ive done!
my other scoot (on here somewhere) is a baotian bt50qt9 with the following - 80cc bbk, ported big valve head, high lift cam, 21mm slide carb, foam filter, 32kv coil, kamikaze cdi, naraku variator 6g, clutch (reds), naraku +10% gears, big bore header & home made carbon can... it's currently awaiting repair as i burnt out the stator on a 1000 mile run!
it runs surprisingly well though, pulls 45 uphill no problem and pulls 50 easy, topping out at 60mph!
i do miss the smell & noise of the 2T though which is why i got the pug!
