Post by luke0000 on Jan 8, 2024 19:06:27 GMT -5
What size jet would you recommend for the upgrades ? I bought a kit that has 80-102
Also the variator kit I bought came with a red clutch/contra spring? Do you think it is to stiff? Tanks
Post by bigmatthew86 on Jan 8, 2024 20:46:05 GMT -5
All brand of jets are different so I can’t tell you there. Pretty sure I’m running a stock Zuma jet in my vino (80) I think. Although the 80 you got could be larger or smaller. If you don’t have a temp gauge you should get one. They are cheap & make tuning way easier. If the red springs you got are the stiffest they are too much. I think I’m running a white contra & the softest of my 3 pack of springs (+500) I think.
Post by Zino on Jan 9, 2024 9:07:59 GMT -5
I ran a white contra or fresh stock contra in my vinos The red is for way more powerful build that should be a wide enough range of jets a temp gauge is a must have for tuning and long term protection of your hard work .
Post by luke0000 on Jan 9, 2024 9:48:31 GMT -5
Do you mind explaining what the temp gauge is used for ?
And what kinda gas do yall run in yo scooter 91?
Post by aeroxbud on Jan 9, 2024 13:13:19 GMT -5
The temperature gauge has a ring which replaces the crush washer on the spark plug. This enables you to monitor how hot, rich or lean the engine is.
Post by Zino on Jan 9, 2024 19:13:31 GMT -5
I run non ethanol regular pump gas 87 or 89 octane
Post by luke0000 on Jan 10, 2024 18:49:27 GMT -5
Ok so I got the temp gauge. Should I put it on the head bolts or do I have to put it on the spark plug. The spark plug would take a lot of work as I would have to notch out a fin. Sorry for all the questions I really appreciate your help.
Post by Zino on Jan 10, 2024 19:39:30 GMT -5
Spark plug works best.
Post by luke0000 on Jan 11, 2024 17:00:34 GMT -5
Ok so I took off the cylinder head and noticed this micro crack?(attached images) Do you think it's ok or do I need to replace the crank or somethhing. if thats the case im not sure if I have enough knowledge to do so lol
Post by oldgeek on Jan 11, 2024 17:12:52 GMT -5
I don't think that is a crack, likely just where they trimmed the casting a bit. Check to see if there is a crack on the inside where the wrist pin bearing rides.
Post by luke0000 on Jan 11, 2024 17:16:27 GMT -5
I think you’re right on the inside there is no cracks at all inside
Post by oldgeek on Jan 11, 2024 17:19:40 GMT -5
I think you’re right on the inside there is no cracks at all inside Why did you pull the cylinder?
Post by luke0000 on Jan 11, 2024 18:06:40 GMT -5
The scooter had trouble starting but would run when engine was hot, had blow by and was eating oil. I was planning on upgrading the cylinder eventually so opened er up
Post by luke0000 on Jan 12, 2024 22:33:23 GMT -5
Alright so I installed the big bore kit and installed new main jet and it now when I attempt to start it sounds like it has compression but then there would be a clicking sort of noise in the cvt area so I would stop. I checked compression and I have about 110psi. Not sure where to start I’m a little discouraged
Thanks a bunch
Post by Zino on Jan 13, 2024 9:43:56 GMT -5
do you have the ground for the kick start under neath the screw
try kick starting it it may just be to much to turn over by the battery
My vino batteries have a hard time turning over with a kit .
