chi
Scoot Junior
Post by chi on Dec 14, 2023 6:02:48 GMT -5
Hi guys. My scooter is Piaggio typhoon 2019 50cc 2t
I installed it
Malossi 70cc bore kit (new) PHVA Carby 20.2 with 95 MJ (will try with 85) ( New) Yasuni R Remove oil pump Mixture 33:1
it was running very well but I got some damaged on Cylinder so I couldn't start it on because of low compression so I change new cylinder but there is some problem I don't know what is that. when I start it on, I tune the carby for rev around 1700 but after few minutes, rev is going up around 2000~3000 rpm and didn't come back down but sometimes it come back to stable around 1600~1700rpm. anyway I tried test driving but first times it was ok but after 10mins drive , cut engine off during WOT(when I put the break on and when I wait for traffic, rpm going very low and cut engine off fews times)
and I pulled over my scooter and tried start scooter but I couldn't just cranking so I did kick starter and it works but it stall fews times when I wait traffic too. I tried to put smaller MJ but same problem and one of my friends said, Maybe fuel system problem so I put New Fuel tap and checked it but it looks fine. I tried every things by myself but I can't find it what's problem...
Need help.. please ... it is very good weather outside ... want to drive side of beach...
That is my Checked list
Fuel lines Carby is New but did clean up Good spark plug ( it was black so look like rich so I put smaller MJ) Good compression coz of new Cylinder
Post by geoffh on Dec 14, 2023 16:14:44 GMT -5
That's a big ol carb you have put on there,I would try the old (presumed smaller) carb but with the jet upsized to cover the extra 20% you have installed.
Post by aeroxbud on Dec 14, 2023 18:54:22 GMT -5
Sounds like you have an air leak. The stock carb would be fine with the setup you have. Which Malossi kit do you have? You can't use the kit for the older models on the Euro 4 models. Are you still running the original Piaggio head?
chi
Scoot Junior
Post by chi on Dec 15, 2023 0:28:24 GMT -5
Sounds like you have an air leak. The stock carb would be fine with the setup you have. Which Malossi kit do you have? You can't use the kit for the older models on the Euro 4 models. Are you still running the original Piaggio head? My model is Euro4 and It’s Malossi sports 70cc and put Malossi head
chi
Scoot Junior
Post by chi on Dec 15, 2023 0:29:11 GMT -5
That's a big ol carb you have put on there,I would try the old (presumed smaller) carb but with the jet upsized to cover the extra 20% you have installed. Geoff So you mean . Try put smaller MJ??
Post by aeroxbud on Dec 15, 2023 5:48:22 GMT -5
You need to run the stock head with the Malossi special gasket. Your ignition timing is going to seize the cylinder. This video explains why.
chi
Scoot Junior
Post by chi on Dec 15, 2023 16:21:18 GMT -5
You need to run the stock head with the Malossi special gasket. Your ignition timing is going to seize the cylinder. This video explains why. Thanks mate. Maybe that problem. I will try put factory cylinder head with temperature sensor.
Post by aeroxbud on Dec 16, 2023 7:26:58 GMT -5
Just make sure you use the proper gasket. Otherwise you will damage the piston. Good luck.
chi
Scoot Junior
Post by chi on Dec 18, 2023 1:06:19 GMT -5
Just make sure you use the proper gasket. Otherwise you will damage the piston. Good luck. I put the other head with temperature sensor but when I full open throttle , suddenly cut engine out.. still same problem
chi
Scoot Junior
Post by chi on Dec 18, 2023 1:37:21 GMT -5
Just make sure you use the proper gasket. Otherwise you will damage the piston. Good luck. I put the other head with temperature sensor but when I full open throttle , suddenly cut engine out.. still same problem After died scooter, I tried to start it but I couldn’t but only kick starter work.
Post by freeqsee on Dec 18, 2023 1:52:16 GMT -5
First check reed valve and intake for any cracks and air leaks. If everything looks fine, try to proper adjust the mixture. As you said, if the spark plug is black it's too rich so give him more air. Also, what type of choke do you have? If it is an electric one, disconnect its cabble and start the engine without choke and see what happens. Maybe this video will help you to proper adjust it: www.youtube.com/watch?v=A1vRMERs4RQ&list=PLRaS4DonNXQneGPDEmM6vn4TjCfMCEC9P&index=1
chi
Scoot Junior
Post by chi on Dec 18, 2023 2:25:44 GMT -5
First check reed valve and intake for any cracks and air leaks. If everything looks fine, try to proper adjust the mixture. As you said, if the spark plug is black it's too rich so give him more air. Also, what type of choke do you have? If it is an electric one, disconnect its cabble and start the engine without choke and see what happens. Maybe this video will help you to proper adjust it: www.youtube.com/watch?v=A1vRMERs4RQ&list=PLRaS4DonNXQneGPDEmM6vn4TjCfMCEC9P&index=1It was rich with MJ 95 so I put MJ88 and look nice after test driving but it was died when WOT for few minutes and then It couldn’t start on . Only work with kick starter. My scoot has E-choke. I tried disconnecting and was same issue.
Post by aeroxbud on Dec 18, 2023 5:23:44 GMT -5
If you disconnected the choke, it would be permanently on. If you did not have the special Malossi head gasket to run the standard head. The piston will hit the cylinder head.
chi
Scoot Junior
Post by chi on Dec 18, 2023 6:02:28 GMT -5
First check reed valve and intake for any cracks and air leaks. If everything looks fine, try to proper adjust the mixture. As you said, if the spark plug is black it's too rich so give him more air. Also, what type of choke do you have? If it is an electric one, disconnect its cabble and start the engine without choke and see what happens. Maybe this video will help you to proper adjust it: www.youtube.com/watch?v=A1vRMERs4RQ&list=PLRaS4DonNXQneGPDEmM6vn4TjCfMCEC9P&index=1If it works well with disconnected e-choke, can I keep disconnected and without choke ?? Yes I put special gasket with factory cylinder head. I will try disconnecting tomorrow and will be back. Thanks
Post by aeroxbud on Dec 18, 2023 7:33:10 GMT -5
It's a different gasket to the one that came with your cylinder. It's thicker.
