Post by patriotk11 on May 9, 2024 7:07:40 GMT -5
I'm going with a rebuild option.
New crank seals New bore, piston, head, plug New exhaust New carb
And pray for the best
Post by patriotk11 on May 9, 2024 13:54:00 GMT -5
So started the strip down. Found the culprit, or certainly something that wouldn't help. The stator side crank seal had blown, literally fell out when I touched it and oil in this dry area.
So all being well I'll do both seals tomorrow and put a new barrel, piston and head on for good measure.
Fingers crossed 🤞
Post by patriotk11 on May 9, 2024 13:55:16 GMT -5
Post by gooddog on May 14, 2024 9:56:44 GMT -5
wrong posting my mistake.
Post by patriotk11 on May 17, 2024 14:05:07 GMT -5
New build is done and no oil leaks or anything. It starts well and I'm definitely getting happier
So I am bearing in mind she needs a run in but she's slow off the mark, picks up ok as the revs pick up a bit but then slows up again. Definitely slower than before, but with a lot of miles left to run in I'm thinking I maybe a jet or something out.
I will let her cool and check the plug colour and go from there
Post by patriotk11 on May 18, 2024 13:53:01 GMT -5
Now have a 72 jet which seems good when riding....
Issues
No power pulling away up to 10mph then you hear the revs pick up and it goes ok.
Minimal power on any type of incline
Any ideas
Post by aeroxbud on May 18, 2024 14:18:24 GMT -5
Rollers too heavy? Need stiffer clutch springs, or contra. When you pull away. The bike should rev up and stay at a constant revs. Does it?
Post by patriotk11 on May 18, 2024 18:37:27 GMT -5
Once it's revving it seems fine on the flat, just struggles to get the revs going off the line.
Post by patriotk11 on May 18, 2024 18:40:51 GMT -5
I'm running 6g rollers.
Will look at the clutch springs, but it pulled well previously. I feel I've missed something 😆
Post by patriotk11 on May 19, 2024 4:55:00 GMT -5
Definitely an improvement with the standard derestricted exhaust. Although it vibrated itself loose within a few miles lol
Post by aeroxbud on May 19, 2024 8:02:26 GMT -5
If it's running better on the standard exhaust then something is not set up correctly. What exhaust was it you have?
Post by patriotk11 on May 19, 2024 9:37:32 GMT -5
It's a derestricted standard exhaust. I bought a newer version. After a longer ride they both do the same off the mark.
It's almost scoot along until you get 10mph then it picks up
Post by aeroxbud on May 19, 2024 13:33:39 GMT -5
Sounds like the revs are too low. If you install stiffer clutch springs. It should take off in the power band. Are they the standard weight rollers too?
