86 gyro
May 19, 2024 13:35:36 GMT -5
via mobile
Post by 2wheelmadman on May 19, 2024 13:35:36 GMT -5
I'm restoring an 86 Gyro and have come across what appears to be a missing part. It is not identified on a schematic or parts diagram.
It's a hole down to the left of the oil pump shaft,has a power connection and a ground right at that location. There are also 2 screw holes ready to take a part.
Any idea what goes here?
86 gyro
May 19, 2024 15:40:09 GMT -5
Post by aeroxbud on May 19, 2024 15:40:09 GMT -5
Can you post a picture of it?
86 gyro
May 19, 2024 18:06:53 GMT -5
Post by 2wheelmadman on May 19, 2024 18:06:53 GMT -5
Post by oldgeek on May 19, 2024 18:28:27 GMT -5
Electric starter goes there.
86 gyro
May 19, 2024 18:46:59 GMT -5
Post by 2wheelmadman on May 19, 2024 18:46:59 GMT -5
Well, I thought so too, but according to the TG50 manual the starter is inside the the drive wheel hub.
86 gyro
May 19, 2024 18:54:15 GMT -5
Post by oldgeek on May 19, 2024 18:54:15 GMT -5
Manual may be describing kick start mechanism or just using different terms. I can assure you that is where the starter bolts on. The single red heavy wire leads back to the starter relay and the green wire goes under one of the starter bolts.
86 gyro
May 19, 2024 19:22:21 GMT -5
Post by 2wheelmadman on May 19, 2024 19:22:21 GMT -5
Thanks. Where can I find the starter motor? Any links? Or a parts site?
86 gyro
May 19, 2024 20:07:11 GMT -5
Post by oldgeek on May 19, 2024 20:07:11 GMT -5
Thanks. Where can I find the starter motor? Any links? Or a parts site? That I have no idea about. I have seen starters that have a wide spacing like that one has but who knows if they will fit. Being Honda you should be able to find something that will work. Good Luck with your resto
86 gyro
May 19, 2024 20:46:28 GMT -5
Post by 2wheelmadman on May 19, 2024 20:46:28 GMT -5
Tx.
Post by aeroxbud on May 20, 2024 2:56:28 GMT -5
Post by jbjhillbilly on May 20, 2024 13:44:54 GMT -5
