sinfull
Post by sinfull on Jul 19, 2024 23:23:47 GMT -5
Not the worst repair on a scooter I have seen. The most rigged up repairs are usually the repairs that last longer than the bike. Thing will probably hold out longer than the other side, usually how it works.
Post by milly on Aug 11, 2024 13:32:54 GMT -5
Well progress on this extremely hot day of 78f here in Wales. The tyres are on by friend over the way after I punctured the inner tube. Turns out in 6 places. The front wheel from honda fitted fine except for an extra spacer courtesy of a ford car. Rear wheel had problem with back plate mounting which would have need a lug welding on swinging arm. A back plate from an old pox spaced out with a shock spacer courtesy of a range rover glued against the bearing to stop it falling into the brake drum every time I tried to insert the spindle or move it. Brake hardware parts from Vespa unknown and a Honda Melody. Top chain case bodgery from a old Chituma CTM 125. Still not tried turning engine over yet
![](https://i.postimg.cc/WzBRJ1t4/IMG20240811162602.jpg) ![](https://i.postimg.cc/nVgfW0Tt/IMG20240811165926.jpg) ![](https://i.postimg.cc/X7566dDB/IMG20240811182115.jpg) ![](https://i.postimg.cc/0ydgbxv8/IMG20240811182123.jpg) ![](https://i.postimg.cc/hGSkmw4V/IMG20240811182134.jpg) ![](https://i.postimg.cc/1zJLrH42/IMG20240811182143.jpg)
Post by FrankenMech on Aug 11, 2024 16:45:59 GMT -5
Sounds like a whole lot of bodgery but I am used to that.
Post by milly on Aug 12, 2024 15:18:38 GMT -5
Tonight I had little time to check out work on it for tomorrow. Now wheel and chain on I was pleased to see it turned over ok when pushed in gear for which I am pleased as thought a seized engine as it has no kick starter fitted to try. The new starter can be fitted tomorrow and I fished out the cut wires which looks like CDI and rectifier wires. Rectifier I have but no CDI but found a second hand one for £14, a wiring loom for £15 with good connector blocks or a loom with all bits attached for £39 or offers. I have a new CDI but if the Pox is like the Peugeot Twat the wiring for the CDI is specific to that model. With my elecktrickery skills it might pay to put offer on the complete loom with all parts. We will see if I can get my head around it and try not get to discombobulated tomorrow. ![](https://i.postimg.cc/pTZ3TXQz/IMG20240812202353.jpg) ![](https://i.postimg.cc/XqYmySxh/IMG20240812202407.jpg) ![](https://i.postimg.cc/yxp5mQbN/IMG20240812202422.jpg) ![](https://i.postimg.cc/Dfxt30wK/IMG20240812202431.jpg)
Post by FrankenMech on Aug 12, 2024 21:14:28 GMT -5
In that third picture has part of the frame been cut away?
Post by milly on Aug 13, 2024 1:20:15 GMT -5
In that third picture has part of the frame been cut away? From memory no FrankenMech, but I will check just incase later when mobile.
Post by milly on Aug 13, 2024 3:10:08 GMT -5
Checked it out FrankenMech and it's just frame building at it's best ☺️ ![](https://i.postimg.cc/BZdjPgCn/IMG20240813085206.jpg)
Post by FrankenMech on Aug 13, 2024 4:11:07 GMT -5
Scooter frame building => Stick cardboard together with blobs of superglue, naw, maybe Elmer's white school glue.
I see you have a new starter.
Post by milly on Aug 13, 2024 9:05:11 GMT -5
Today's jobs after doing the garden was a professional job of sorting the ignition lock as it came with no key. Then to town for starter motor bolds. Now rain stops play. Hmmm looking at the bench in the picture I think it is time to tidy it up at some point. ![](https://i.postimg.cc/qvFw9JDj/IMG20240813113612.jpg) ![](https://i.postimg.cc/25BGYsPm/IMG20240813115107.jpg) ![](https://i.postimg.cc/DZkgwCTG/IMG20240813144556.jpg)
Post by FrankenMech on Aug 13, 2024 10:50:41 GMT -5
Your bench looks better than any of mine. Any flat surface in my house tends to accumulate maximum slope debris. I don't get around well and am always too tired after working to put anything back where it belongs or clear up any debris left over from any project.
