Post by milly on Nov 6, 2024 8:41:55 GMT -5
One wire to remove and old loom off. New loom in place bit of finishing off to do. Air filter needs front mudguard removed to remove it so carb can be cleaned and a couple of spade terminals for the starter lead.
Post by FrankenMech on Nov 6, 2024 9:15:12 GMT -5
Nice work, Make sure you crimp new terminals to last with silicone and proper crimper tool. Factory crimped terminals are difficult, about all you can do in coat them with silicone grease to try to keep moisture out. Once corrosion starts that damn oxygen gets in...
Do you ever wash stuff -before- you start working on it? It makes stuff easier to work on after it dries. I have found those leaf blower things do great for getting rid of the water afterward. Then just let stuff air dry, -get a beverage or two or three (non-alcoholic) down at a local before working. Alcohol never improves workmanship but conversations with friends can help attitudes.
Looks like there is still much 'reliability' type work to do replacing rubber lines, seals, filters, etc. The type of stuff that can interfere with pleasant rides out in the fresh air.
Post by milly on Nov 6, 2024 9:35:57 GMT -5
Wash stuff FrankenMech! It will only get dirty again! Talking of Lunatics have taken over the asylum I see the orange haired one is edging forwards.
Post by FrankenMech on Nov 6, 2024 10:05:21 GMT -5
It is far worse than that.
Post by milly on Nov 7, 2024 13:08:25 GMT -5
Post by aeroxbud on Nov 7, 2024 15:52:55 GMT -5
Yeah that's probably not going to fit without some modification then.
Post by FrankenMech on Nov 7, 2024 19:53:27 GMT -5
Floor panels were made for using that aluminumiumun diamond plate.
Post by milly on Nov 8, 2024 12:24:04 GMT -5
Kick start arrived along with rear panels and light. Kick start being a pain to go on. Just in town now getting M5 and M6 nuts and bolts to stock up on and finish tomorrow a visit from the red heads curtailed work. Now off to the chip shop for takeaway Fish and chips with mushy peas for tea.😊
Post by FrankenMech on Nov 8, 2024 18:31:22 GMT -5
I bought some 36GB USB drives for backing up a few files, Started a download of Linux Mint. Went to store for chicken tenders, mashed potatoes, and green bean casserole. -No mushy peas for me.
Post by milly on Nov 10, 2024 11:53:27 GMT -5
Post by FrankenMech on Nov 10, 2024 12:27:14 GMT -5
Yuck
Post by milly on Nov 10, 2024 13:59:58 GMT -5
Indeed FrankenMech, I best save my daughter the entomologist a sample to look at under a microscope see what we have living in that.
Post by FrankenMech on Nov 10, 2024 18:32:03 GMT -5
Seems strange to be growing any green plant type stuff in the dark but may just be green brass corrosion and bacteria.
Post by milly on Nov 11, 2024 11:33:54 GMT -5
Tool tray arrived and fitted, carb been in the sonic cleaner and now reassembled. Finish a bit more after work tomorrow hopefully.
Post by FrankenMech on Nov 11, 2024 17:31:34 GMT -5
If you get some of that Boeshield T-9 from Amazon or Boeshield.com it will help protect both steel and aluminum from corrosion. It is great for bicycle and motorcycle chains also. It is another thing for your chemical mechanic's toolbox. Unfortunately I do not know if it is available in the UK.
I am also very diligent about using anti-seize on steel fasteners going into aluminuminium. It is available as a brush-on paste and also as a wax type crayon that is real handy for the toolbox.
