theo547
Post by theo547 on Jan 21, 2012 0:51:36 GMT -5
30 bucks is petty cheap in my book
zedooo
Post by zedooo on Feb 3, 2012 17:43:41 GMT -5
I just took the battery from the alarm system at my job, found it in the warehouse
Post by Deleted on Feb 18, 2012 4:10:20 GMT -5
We have a member here with a 52.4x44 qmb stroker engine. He has not posted here in awhile but I saw a post he made elsewhere and he is now using a whopping 235cca battery because that big motor was impossible to crank over. If you are planning a qmb bbk add a battery of at least 90cca to your list
theo547
Post by theo547 on Feb 20, 2012 20:50:33 GMT -5
Ok guys added the new battery, and finally got the engine together... when im trying to crank the engine over the ground coming off the resinator (green wire) is burning up... is it possible that im trying to put a DC engine on an AC setup?! or is this over sized battery causing this problem... it sounds like the engine is trying to start.
Any ideas what could be doing this?!
I did not upgrade any of the ground wires when i added the new battery.
Post by Deleted on Feb 20, 2012 20:52:52 GMT -5
you mean the rectifier/regulator?
Post by Deleted on Feb 20, 2012 20:55:09 GMT -5
sounds like some wires are crossed somewhere.
theo547
Post by theo547 on Feb 20, 2012 21:07:33 GMT -5
sorry yea lol Stator... havnt been doing alot of scooter stuff this winter - i dont think any wires are crossed... i had previously had this scooter running with a diff engine and battery... all i did was upgrade the wires from the battery to the relay and from the relay to the starter.... did i miss a step?!
Post by Deleted on Feb 20, 2012 21:10:45 GMT -5
the stator? the green wire from the stator the wire is burning up? never seen that before.
theo547
Post by theo547 on Feb 20, 2012 21:12:52 GMT -5
yep i was pretty floored by it also, thats why im wondering if maybe its one of those rare DC ones.... i just dont know what else could be causing that.
No other wires are having this issue... atleast that i can see or smell.
Post by Deleted on Feb 20, 2012 21:13:25 GMT -5
wait there is no green wire from the stator...you mean the square thing?
Post by Deleted on Feb 20, 2012 21:14:17 GMT -5
this?
theo547
Post by theo547 on Feb 20, 2012 21:22:39 GMT -5
Post by Deleted on Feb 20, 2012 21:27:42 GMT -5
thats a DC stator
so that must not be the original engine
theo547
Post by theo547 on Feb 20, 2012 21:30:16 GMT -5
well f%^& me sideways..... i was hoping that wasnt going to be the issue...
Post by Deleted on Feb 20, 2012 21:32:21 GMT -5
i could be wrong too but all my AC stators here have no green wire.
