jcoahran
89 zuma ii
Post by jcoahran on Mar 26, 2012 16:47:39 GMT -5
well, the title says most of it, ive changed the spark plug, fuel lines, and carb, still won't start, this is a tao tao 50...i put some gas on the end of the spark plug, and it starts right up and runs like a dream, but when i shut it off, it won't start again...until i put more gas on the end of the spark plug...could the valves need to be loosened? i dont know...please help me, as i need this scoot for work...and im already...45 minutes late... :swear:
Post by Deleted on Mar 26, 2012 16:52:51 GMT -5
tight valves can cause hard starts yes.
jcoahran
89 zuma ii
Post by jcoahran on Mar 26, 2012 17:07:54 GMT -5
is tha all that could be causing this problems? i mean it HAS to be something to do with where the gas enters the motor? that still doesn't explain why it still drives no problem once its started.....maybe i oughta start it...and beat the shit out of it and hope for the best? lol im being sarcastic.
Post by 90GTVert on Mar 26, 2012 17:11:16 GMT -5
I doubt it's the issue, but check over your vacuum lines too. Might wanna take the fuel line off of the carb and be sure it shoots gas out when you kick it over. Both just on the possibility that vacuum could be a little weak or the vacuum petcock could be starting to have trouble.
jcoahran
89 zuma ii
Post by jcoahran on Mar 26, 2012 17:14:24 GMT -5
i thought of that, but i can't figure out what a petcock is, or where it is, would you mind letting me know please? thanks and im a noob when it comes to scooters, this is my first one...(i wanna learn about motors so i figured id start with the smallest and work my way up) how can i tell which is the vacuum lines?
jcoahran
89 zuma ii
Post by jcoahran on Mar 26, 2012 18:24:37 GMT -5
okay i found all of that, everythings perfect, could i have burnt out my cdi??? if so is there a way to bypass the cdi!?
Post by larry001964 on Mar 26, 2012 18:31:31 GMT -5
Nope no way to bypass the CDI, thats the bad news, the good news is if the CDI were faulty your scooter would not run at all. I would adjust the valves.
jcoahran
89 zuma ii
Post by jcoahran on Mar 26, 2012 18:32:47 GMT -5
it only runs when i FEED gas into it...i put gasoline on the spark plug, then it fires...
jcoahran
89 zuma ii
Post by jcoahran on Mar 26, 2012 18:33:33 GMT -5
nor electric or kickstart will fire it atm...
Post by larry001964 on Mar 26, 2012 18:44:31 GMT -5
Then its not getting fuel, clean the carb especially the idle and main jet check the float needle valve, vaccume line going to fuel petcock, take off fuel line on carb, place in jar, suck on vaccume line, see if you ger fuel flow, check also fuel filter. Hope it helps
jcoahran
89 zuma ii
Post by jcoahran on Mar 26, 2012 18:49:21 GMT -5
well, this is the part that confuses me, i took the carb off of my dads 50cc (his runs PUUUURRRRRFEECT) and put it on mine, same thing...i did notice...from the petcock to the carb...theres a hose...i took it off and tried to start it to see what would happen...nothing...i dont know if thats normal or what..it acts like it WANTS to start, but never really does, thats why i was askin about the cdi...ive tried everything, and im probably going to lose my job tomorrow if i cant come..
jcoahran
89 zuma ii
Post by jcoahran on Mar 26, 2012 18:52:55 GMT -5
****the hose from the petcock is NOT the fuel line...its getting fuel i know that much, the hose im talking about is on a valve on the top of the petcock
Post by larry001964 on Mar 26, 2012 18:52:58 GMT -5
Sounds like fuel petcock or filter.
Post by larry001964 on Mar 26, 2012 18:57:25 GMT -5
The hose on top of the petcock is the vaccume line. It goes to the nipple on the intake
jcoahran
89 zuma ii
Post by jcoahran on Mar 26, 2012 19:09:41 GMT -5
thats all the info i have on it, do you still think its the valves? if so, how do i fix them?
