Post by shakerdriver on Mar 26, 2012 20:08:59 GMT -5
My 150 was the same way tweak and it turned out to be a crack in the intake, check it real close.
Post by Deleted on Mar 26, 2012 20:09:28 GMT -5
thats what i meant by hard to crank. hard to start. crank=crankup=start.
this engine needs a valve adjustment and a good unseald properly jetted and adjust carb.
Post by Deleted on Mar 26, 2012 20:11:24 GMT -5
My 150 was the same way tweak and it turned out to be a crack in the intake, check it real close. and if it wont idle then yes definitely this too. remove the intake manifold and inspect it i have seen them crack under the clamp where you cant see it.
Post by shakerdriver on Mar 26, 2012 20:11:34 GMT -5
It has a plastic spacer under the rubber/metal intake 90* boot and a rubber oring gasket, it could one of them also if it wasn't assembled properly when "rebuilt".
Post by larry001964 on Mar 26, 2012 20:15:56 GMT -5
:welcome: thats what i meant by hard to crank. hard to start. crank=crankup=start. this engine needs a valve adjustment and a good unseald properly jetted and adjust carb. Yep yep yep !! :-)
jcoahran
89 zuma ii
Post by jcoahran on Mar 26, 2012 20:18:26 GMT -5
first thing tomorrow morning, i will do the valve adjustment, then check the intake for cracks, if this doesn't work, ill post back here...if it does work, then i will DEFINITELY post pics of my scooter here, and all the mods i plan on doing to it.. thanks so much for the help guys! im now a regular on this FANTASTIC site. thanks again!
Post by teddy554 on Mar 26, 2012 20:22:19 GMT -5
this is how you check your valves dont have to remove your motorand spark this guy is the man so pay attention
Post by Deleted on Mar 26, 2012 20:26:24 GMT -5
well its best to remove the spark plug so the motor is easy to turn over by hand to line the marks up but yeah he is the man
jcoahran
89 zuma ii
Post by jcoahran on Mar 26, 2012 20:34:29 GMT -5
okay, i downloaded the video so we can actually see it o know what to do, thanks VERY much guys!
Post by Deleted on Mar 29, 2012 14:54:47 GMT -5
uh oh. « Message sent Today at 1:57pm from JTweak » uhh, we finally got the valves adjusted...and its still not starting :/
Time for a compression test JT.
you need a compression gauge and a 10mm fitting for it.
did you inspect the intake manifold for cracks?
jcoahran
89 zuma ii
Post by jcoahran on Mar 29, 2012 15:37:53 GMT -5
yes sir i did, and i don't have a compression guage, but like i said, once i put gas on the plug and put it back in, it starts fine...from the looks of it, im going to have to keep a jar of gas...a wrench and a plug socket with me at all times -.-
Post by Deleted on Mar 29, 2012 15:48:02 GMT -5
jcoahran
89 zuma ii
Post by jcoahran on Mar 29, 2012 16:15:52 GMT -5
i don't think its a carb problem though, its a sealed carb yeah, but i took my dads unsealed carb and put it on mine for testing...didn't work...
Post by Deleted on Mar 29, 2012 16:42:20 GMT -5
i don't think its a carb problem though, its a sealed carb yeah, but i took my dads unsealed carb and put it on mine for testing...didn't work... A sealed carb is a problem waiting to happen. did you closely inspect the insulator spacer under the intake also? what you describe sounds like a massive vacuum leak....calm down a little and take a breath ok outside of the possible intake leak this is a matter of methodical diagnosis. It is time for a compression test because you might be beating on a dead horse. Even if it does have an intake leak doing anythign with that when it has low compression is wasted effort.
jcoahran
89 zuma ii
Post by jcoahran on Mar 29, 2012 17:00:23 GMT -5
i just checked the spacer under the intake...no cracks breaks or anything..i guess i'll have to wait until we can afford to put some gas in the truck and haul it down to ace, or o'riellies to do the compression test. my dad said tonight we're gonna start taking break his engine down piece by piece and put the parts on mine until it starts, so we can find the problem that way, (i really dont wanna do that but i have hardly any say so in it) what could cause low compression? could it be because we gutted the exhaust? (i dont see that being the cause because it still runs when i put gas on the plug) but yeah... thanks so much 1fast for everything you've helped me with, i greatly appreciate it.
