Post by Deleted on Apr 19, 2012 20:59:32 GMT -5
I wonder why they didnt just put a 39mm bore on them with the right jetting so it wouldnt run hot and burn the rings up? I guess because they have a few warehouses full of 144QMC motors stamped 139QMB to get rid of lol.
Post by Deleted on Apr 19, 2012 22:06:18 GMT -5
Took this with the my LG optimus S Android phone....aint the best lol. I have yet to get the GoPro out and use it because I dont even know how to yet and this was easier for now. She cranks up easy now
Post by Deleted on Apr 19, 2012 22:07:09 GMT -5
i couldnt hold the brake and push the start button and hold the phone at the same time so i put a bungee on the brake...then forgot lol. If can ever get half as good as Brent and LJ on making videos it will be seriously happy !! ;D
Post by 90GTVert on Apr 20, 2012 5:50:18 GMT -5
Seems to run well now. Fire that GoPro up, it's simple. If it's like mine (earlier model), hold the button on the front till it beeps a few times so you know it's on. Press the button on top and it will beep and a red light will start to flash so you know it's recording. Press the top button again to stop. Hold the front button again to turn off. Simple. Refer to the manual for all the settings if you wanna change resolutions and such. Once I get mine set to whatever resolution I want, the only option I ever change is whether it's filming upside down or right side up. USB connection to PC, it should install itself pretty much. Then it's up to just how you wish to edit it.
Post by 2strokd on Apr 20, 2012 8:13:45 GMT -5
I want one! A gopro that is!
I know, these carbs are getting silly with absolutely no adjustments. Almost have to plan on spending $30-100 on a new carb. Or spend time making the OEM one work, if possible?
Post by 2strokd on Apr 20, 2012 8:14:23 GMT -5
Bet they run great in China!!!?? LOL!
Post by aeroxbud on Apr 21, 2012 15:16:27 GMT -5
They do. This is just what they sell Foreigner's lol
