Post by tropical on May 24, 2013 1:09:24 GMT -5
My ATM has a little over 300 miles, that were on the bike when I bought it a couple of weeks ago. I' m thinking stock is fine with me except changing the carb. I do drive on a cinder dirt road for a short stretch, when it dry it,s very dusty. Would an upgrade on the air filter be a good idea, like the uni high flow GY6 50.? Then would the keihin PD185 18 mm 85 , 90 95 jets be the right chose? How often to you clean a filter? How often with the sea foam , which I already use in my car, and how much in such a small tank. I will be checking out the tech library. I seriously appreciate the advise, an expertise. Thanks
Post by 90GTVert on May 24, 2013 7:28:50 GMT -5
The carb & jets sound about right. I would suggest checking/cleaning your filter every 500 miles and keep an eye on it. I like to do oil changes that often, so check the filter every time you do an oil change. In a dusty environment, it shouldn't be hard to tell when it needs cleaning. You can pick up cleaning kits for the UNI that include cleaner and UNI filter oil for after it's cleaned for about $15. With a small filter like our scoots use, it should last quite a while.
Post by tropical on May 27, 2013 16:51:24 GMT -5
There is the smell of gas in the shed where the ATM is parked, is that normal? Or would a different gas cap change that? Looking into getting a scooter carrier for the back of the suzuki grand vitara, aluminum,37lbs. Problem is I Have a one and a quarter receiver, carrier needs 2 inch receiver. I can get an adapter , but would it be strong enough to carry scooter for a long drive? Thanks
Post by toastiestaotao on May 27, 2013 22:34:03 GMT -5
Yea its normal.
Post by toastiestaotao on May 27, 2013 22:35:04 GMT -5
That, or mines doing it too and its an issue we BOTH need to address!
Post by toastiestaotao on May 27, 2013 23:03:03 GMT -5
Try taking the baffel off the tube on the front of the air box and plug it. Then plug the tailpipe. I would think this would cut down on the fumes but I'm not sure if it would have any affect on the overall health of the scoot, so I'm not doing it until someone else who knows more replies with a yea or nay.
Post by toastiestaotao on May 28, 2013 22:04:07 GMT -5
Have you taken your carb apart recently? My gasket was on wanky so it had a slow drip of gas...
Post by tropical on May 30, 2013 12:31:58 GMT -5
Gas smell a lot better, I think it was overfilled . I,ve read about the UNI high flow air filter ,but it sure looks a lot diffrent then what's on the ATM 50 now. How does that fit ?
Post by 90GTVert on May 31, 2013 10:22:56 GMT -5
It fits over the mouth of the carb and the airbox is totally removed. You would need to do something with the crankcase vent that normally runs to the airbox... 49ccscoot.proboards.com/thread/997/crankcase-ventingYou'll need to tune the carb with a larger main jet at least.
Post by taotaonoob on May 31, 2013 13:28:28 GMT -5
hey im planning on getting a tao tao 50cc its a 2011 by what the guy is telling me it has 22k miles i dont know what he means by that.. but he says it has not givin him any problems in the past 2 years he has had it .. but i have read this hole thred and im very informd about the carbs being the main issuse with these but are there any other problems with this scoot i shoud be scared of i use to own a rucks like 4 years ago but it was stolen from my old job -_______- ... so now i found a good priced tao tao scooter in working order and just want a heads up on it thanks
Post by stepthrutuner on May 31, 2013 14:10:42 GMT -5
A 22,000 TaoTao 50 belongs in a museum AND in the Guinness Book Of Records
Post by Deleted on May 31, 2013 15:06:53 GMT -5
probably means 2200 kilometers
Post by 90GTVert on May 31, 2013 19:30:20 GMT -5
hey im planning on getting a tao tao 50cc its a 2011 by what the guy is telling me it has 22k miles i dont know what he means by that.. but he says it has not givin him any problems in the past 2 years he has had it .. but i have read this hole thred and im very informd about the carbs being the main issuse with these but are there any other problems with this scoot i shoud be scared of i use to own a rucks like 4 years ago but it was stolen from my old job -_______- ... so now i found a good priced tao tao scooter in working order and just want a heads up on it thanks to the forum. If it's 2200km or 2200mi, the previous owner prob shook the Chinese bugs out for you. I would change all fluids and go over the CVT as well as performing a valve adjustment. Have a look at the spark plug just to see if anything is obviously wrong.
Post by taotaonoob on Jun 5, 2013 13:27:08 GMT -5
Well guys I just picked up a 2012 Tao Tao atm50 with 0 miles on it I paid 650 for it ....now my question is should I change the carb on this one or wait a lil bit ?
Post by taotaonoob on Jun 6, 2013 9:53:14 GMT -5
is there any threds about mods for these scooters like lowering them mufflers etc......
