Post by one1 on Apr 28, 2012 20:22:34 GMT -5
Post by 90GTVert on Apr 28, 2012 20:51:39 GMT -5
You will want to position the rings so the gaps don't line up with each other.
Post by one1 on Apr 28, 2012 23:16:27 GMT -5
SO opposite of each other perhaps?
Also, the third thicker ring has openings on each side, any position relative to that?
It's left and right so maybe one main ring up and one down?
Post by Deleted on Apr 28, 2012 23:57:22 GMT -5
Post by 90GTVert on Apr 29, 2012 5:48:50 GMT -5
Here's an excerpt from a GY6 service manual that shows a common ring placement....
Post by one1 on Apr 29, 2012 18:25:13 GMT -5
Thank you, I guess I'll do it like this
Post by one1 on Apr 29, 2012 23:37:37 GMT -5
Post by lshigham on Apr 30, 2012 2:30:31 GMT -5
The rings are designed to rotate in use anyway to limit carbon build-up in the ring lands, so don't worry about it too much.
Post by one1 on May 2, 2012 16:17:35 GMT -5
Here it begins............. first thing to show.
Post by one1 on May 7, 2012 13:45:45 GMT -5
So the case is here and the hole for the shift tumbler is a little different. Looks like it will fit though so let's give it a shot! I believe this ATV was an automatic based on what I am seeing.
Post by one1 on May 7, 2012 22:38:17 GMT -5
