Post by aeroxbud on Feb 5, 2013 16:37:57 GMT -5
I just use a locking tool, like this
Post by 90GTVert on Feb 5, 2013 16:44:55 GMT -5
Nice to see how that tool is supposed to work. lol I have that tool, but the Chinese cases are different, so I have to rest one side of it up against the frame. At least it still works.
Post by Fox on Feb 6, 2013 0:23:55 GMT -5
I love my $30 impact.
Post by ottootto on Feb 6, 2013 5:58:33 GMT -5
think most of engine here are minarelli-yamaha or china copy easy and clean way fo vario
Post by aznatama on Feb 15, 2013 23:34:59 GMT -5
I just found out how to use this Y-shaped thing to remove the variator... you ahve to use it on the flywheel side and hope it doesn't fall off when you're on the other side working on the variator nut... PITA
Also, the Buzzetti tool doesn't work on all scooters, your case holes have to miraculously line up, and then you'd have to have a case that has high walls or find some long bolts to hold it down and hope you don't damage the case bolt holes... useless as well.
The engine side of my case is almost completely flat, no "walls." The cover has high "walls." The Buzzetti tool holes (if they lined up) would be about 2+ inches above the bolt holes. Bracing it against the axle won't work, not enough pressure to prevent the castle nut from just prying it away.
Post by 90GTVert on Feb 16, 2013 0:06:23 GMT -5
Post by ottootto on Feb 16, 2013 20:31:05 GMT -5
sorry don t know , luckily here i can choice between , yamaha -minarelli- china copy crap and piaggio so i never found issue coz piaggio itz piaggio....
Post by Goosey on Feb 17, 2013 15:27:54 GMT -5
Sorry to change subject here, but to keep the peace we try not to refer to any make scooter as "crap". My Baron is crap. But my Roadrunner isn't. I can't blame China for that, just the facory and importer at the time.
On subject, I think that tool would be great for on the road. I don't believe it's compatable with the 150cc? I do use the 12volt impact though, it won't fit in my tool bag. I'de pack it for long rides.
Post by 90GTVert on Feb 17, 2013 15:40:30 GMT -5
Post by Goosey on Feb 17, 2013 15:49:53 GMT -5
Post by 90GTVert on Feb 17, 2013 15:58:04 GMT -5
Looks like it might work. I'm not sure what the size is of the holes on the 150 variator. The one I linked to is 5mm and 9mm. That is only 8mm and then the rectangular side.
Post by Goosey on Feb 17, 2013 16:13:25 GMT -5
I shall take the plunge and give it a shot. Good to have the basic tools for emergency use handy.I love my 12v impact, but too large to take everywhere. I have an excuse to try it out already when I change the variator fan thingy when it warms up around here. Since I have no strenghth in my shoulder it will really test how handy it is.
Post by ottootto on Feb 17, 2013 16:26:43 GMT -5
Sorry to change subject here, but to keep the peace we try not to refer to any make scooter as "crap". My Baron is crap. But my Roadrunner isn't. I can't blame China for that, just the facory and importer at the time. On subject, I think that tool would be great for on the road. I don't believe it's compatable with the 150cc? I do use the 12volt impact though, it won't fit in my tool bag. I'de pack it for long rides.  sorry...
Post by Goosey on Feb 17, 2013 21:36:48 GMT -5
 sorry... All good.
Post by aznatama on Feb 18, 2013 19:59:33 GMT -5
I couldn't do that with the tool, the castle's teeth weren't deep enough to hold onto the tool without the tool sliding off. If I could find a castle with higher/ more well definied edge, perhaps it would work then, but for now, I'll just deal with removing the fan cover and fan, and using the Y-tool thing to lock the rotor
