Triton # 2 (T2) 49cc to 110cc & Nearly Everywhere In Between
Nov 6, 2018 16:57:21 GMT -5
2strokd, 190mech, and 4 more like this
Post by 90GTVert on Nov 6, 2018 16:57:21 GMT -5
I thought I should update this thread so it makes sense for anyone seeing it that hasn't seen what's up and to make it easier to follow. Plus, a few more details about the scoot.
So, I did go to H2Oi that Friday (Sep 28) as I posted about last. The scoot ran great. I tried to get cars to race me all night, but they suck. lol Did a few little wheelies at low speed, just hopping the front up and coming back down (I can't ride a wheelie). Had a lot of fun.
I ended up riding over 240 miles Friday. Gas mileage was pretty horrible. It averaged almost exactly 30MPG (29.95MPG). Best tank of 31.3MPG and worst of 28.1MPG.
I intended to go the next day as well. I went out and there was a little coolant puddle under the radiator on the right side of the scoot. Maybe silver dollar size or slightly bigger. I checked hoses and they seemed tight. Couldn't find anything obviously wrong. Coolant level was OK. Didn't worry me enough to keep me from going to the show.
I refilled oil bottles and did whatever I needed to get ready to leave. Got my gear on and was all ready to leave when the CVT cover broke as I tried to kick start it.
I grabbed another cover that I had around, a deep cover from a short case. I usually try not to use these because there's less contact between the bearing and the drive shaft because of the cover depth, but it would have to do so I swapped the kick lever onto it and quickly drilled a few holes in the clutch area for better cooling.
That did the trick so I headed out toward the beach in the morning. I was leaving earlier than normal, planning to make a really long day of it. Turned out to be one of the longest days of my life, but I'll get to why later for anyone that doesn't know already.
I made it to Seaford, DE. That's about 20 miles away from my home on the way to Ocean City, MD. I noticed it was running a little warmer than normal at times, but nothing that really troubled me. I went through the town and saw an older man on a 4T similar to a TaoTao ATM50. Of course I revved at him as I went by. Just after that, I noticed that the clutch wasn't disengaging when I came to a stop. The 103cc had enough power to still pull away from stops fairly well, but I pulled over to see if I could see anything obvious through holes in the CVT cover. By then, I was multiple streets away from the scoot that I saw, but of course he rode by as I was stopped and looking it over. Probably laughing to himself about the hot-rodding fool now having scoot troubles.
I saw a few little pieces of belt fluff (what you get when these kevlar belts fail or start to; kinda resembles cotton candy but yellow in this case). Decided to move the scoot to a better spot for working on it to take the cover off and have a better look, but that wasn't as easy as I thought it would be. The scoot didn't want to start. I tried for a bit and got nowhere. Decided to just push it to a better spot for now. Of course I live in a flat area and I had to be at the bottom of the 1 hill anywhere nearby with wet grass and no shoulders. Up the hill I pushed, to a gravel area on the side of the road.
I pulled the CVT cover off and found a clutch spring lying in there. Ah, that would explain the constant engagement. The spring wasn't broken, just a little beat up from running into pulleys or the bell I guess. The belt actually wasn't that bad. I knew that I would have to go home to fix the clutch, and the belt looked good enough to get me home so I left it.
Then I had the problem of the no-start. It persisted, so I ended up taking the spark plug out. That was covered in fuel. With a new plug, I got it fired up and went back home. 44 miles of riding, just to end up home to do some repairs.
I took the CVT apart and found that the pin that holds the clutch shoe on had sheared off.
I dug through spare parts and found another clutch with stiffer springs installed. I didn't bother with any tuning, just installed it and called it good enough. I figured it may not work quite as well for launches, but should be OK since it wasn't horrible even with the broken clutch. I believe I changed the belt as well during the process.
While wrapping things up and getting the scoot ready to head out again, I noticed that the water pump was sitting out from the engine.
I thought the bolt must have worked itself loose or maybe I screwed up and didn't tighten it all the way. I was not that lucky though. When I took a closer look, the mounting tab was broken off of the water pump and still bolted to the engine. The stress from having just one large bolt holding the pump also broke the stator cover's corner off.
Crap. I didn't have a spare water pump assembly. I had sold my Prius pump already, so I couldn't even rig up an electric pump quickly. I was immediately defeated and went in the house. No more car show for me.
That lasted a couple of hours. Then I got antsy and was really missing the ride. I decided to go back out to the garage and not let this beat me so easily. I at least had to see if there was anything I could come up with that may let me ride that day.
I ended up using 1/8" thick steel to make a new mounting tab. I took one piece cut thin and bent it in a curve to match the ID of the water pump housing. I drilled the housing and that piece and bolted the steel to the water pump. Then I cut a piece to act as the tab itself. I mocked it up so everything would be where it needed to and tack welded the tab to the curved steel, then took it apart to make a bead across it before reassembling.
Hot damn, it actually worked and I could go to the show! Can't say it was without a hitch though. It looked like the loose cover had damaged the water pump's plastic drive wheel and wore down the rubber pieces on the drive bolts. I figured it would work well enough. If not, I could turn around and come home again. Had to try though.
I went to the car show and it ran great. Temps did get 10-20F warmer than I'd like at times, but nothing too alarming. I assumed the pump drive must be less than 100%, but it would get me through the day/night. The scoot actually ran harder than I think it ever has. It was jumping the front end up about as easily as when I had the racing flywheel and stator on it in the past, and I've never been able to get it to act like that before.
It was not without issue however. I noticed on the ride to and from that I couldn't hold it WOT for long or it would bog like it was running out of fuel. Not a problem for red light races in town, but no very heavy throttle cruising. Still, I had no trouble running 55-60MPH. It was strange though. I had similar issues just before the show, but had them ironed out, or so I thought, with a float height adjustment. Then earlier in the day it flooded. On long stretches is did the opposite and starved. As the night went on in town, it got richer and richer at idle or very low throttle. Sputtering around with idle dropping. I had to pull over at one point and try to lean it out and raise the idle speed. It also died on me in front of traffic after a couple of small wheelies in close succession, as if it ran out of fuel, and then restarted and ran great again. I'm not sure what's up with the carb.
On that topic, my horrible gas mileage got even worse. Day 2 ended up being just over 230 miles of riding and fuel economy averaged 27.96MPG. Best tank of 30.8MPG, worst of 23.3MPG. 23.3 was in town after it started getting noticeably rich at low throttle.
Video from the show is below. You can see it die on me after the little wheelies at about 16:44.
I left the beach at roughly 1AM. Wanted to hang around, but it had already been a long day and the ride home is roughly 2 hours if I keep a good pace. Unfortunately, I didn't make it home as planned. I was 2.5 miles from home when I hit a deer and crashed. Just before that, the coolant temp got up to 160F or so and I slowed to maybe 40MPH or a little less to keep it cooler. The full story and video of the deer crash is in the link below. Long story made short, it was a really hard impact and I broke my shoulder blade in 2 places, 2 ribs, collar bone, and the tibial platea (top of tibia, center of knee) as well as a contusion after a hit that knocked me out for a couple of minutes. I'm still healing from it. Again, check this link for all of the crash details and health updates and such.
49ccscoot.proboards.com/thread/23671/crashed-struck-deer-video-page?page=1
Even being that messed up, I was going to start the scoot and limp it home. I turned the key on and there was no response though. With no headlights and hurt, I wasn't going to attempt to ride. It went home in the back of the truck before I got a ride to the hospital.
Regarding that really long day comment earlier; I started riding at first sometime in the morning on Saturday September 29th. When I hit the deer, it was about 2:45AM Sunday September 30th. I never got out of the hospital and home till late at night on Sunday. No food or sleep for 48 hours or so and all of the injuries made it quite a long "day".
It took me about a month to even really look the scoot over because of my limited mobility. Part of me really wanted to look at it ASAP, but I knew I couldn't ride anytime soon anyway so I waited till I at least got a little better.
The puddle under the right radiator after sitting for a month.
You can also see that there has been coolant splatter all in the area of the radiators.
I'd like to pressure test the cooling system to find where it leaks. I'm afraid it may be leaking from the fan's nylon cable mounts rubbing tubes, but I hope it's something cheaper and easier to fix. I have a pressure tester for cars, but no adapter for the comparatively tiny radiator cap on this.
I'll also need to fix the water pump issue. I could probably keep the busted housing with my fix and replace the drive wheel that's worn and rubber bushings. I will keep it as a spare, but I have a different plan. Immediately after I found the pump to be broken, I went in and ordered a stock housing from a DRR/Apex ATV through g-forcepowersports.com as well as a set of their head gaskets/o-rings to see if they're any tougher than what I've been using from HOCA/Motoritec. I already had a pump rebuild kit around and a Stage6 high flow mechanical pump, so I will try to use those with the stock housing once I'm up to working on the scoot.
Now for the crash damage.
The front end took the hit from the deer.
Looks like the steering stem is bent. When the bars are straight, the wheel is turned and vice versa. I can also see that the forks are at slightly different angles. I don't think the bars or frame are bent. Hopefully just the stem.
Probably the most obvious damage is the headlight and bracket as well as the busted turn signal.
I'll have to make a new 1/8" steel bracket. The headlight housing is shot. Needs new turn signals. The headlight is OK though. I made sure both beams work and I think I only have bugs on the front to be cleaned off.
The headlight was pushed back into the fuse block and some wires were ripped out.
What was left of my front leg shield is busted.
The left brake lever and bar end mirror need to be replaced.
Otherwise, the foot peg cover on the left side needs to be replaced and then it's surprisingly clean considering it crashed on the left side.
Right side and rear appear to be fine.
That should have the thread up to speed on current conditions. Sorry it's a bit of a novel, but we know I like details.
