Triton # 2 (T2) 49cc to 110cc & Nearly Everywhere In Between
Aug 29, 2019 19:53:35 GMT -5
190mech, aeroxbud, and 1 more like this
Post by 90GTVert on Aug 29, 2019 19:53:35 GMT -5
I started out by cleaning up some parts and going over the cylinder deck again. Here's the cylinder before.
I spent much more time going through the grits on glass than I did last time. I didn't use 60 at all, but spent a while with 80, then 120, then 180, then 220, then 320, then 400, and finally 600 grit with Mother's polish as a lube instead of WD-40 like the rest. Here are after pics. Definitely a different finish. I can't get all of the visible lines out... or maybe I could with enough time, but I think it should be sufficiently smooth. Even before, I couldn't feel any of the lines that you see. Oh, the specs are just lint from a paper towel that I had used right after the sanding for a quick cleanup.
One of the studs has been a bit weird in the newer case half since I first replaced that half. Sometimes it acts like it wants to slip instead of torque down and I'l back it off and redo it. I went over them all a couple of assemblies ago, but it still happened. I ran taps into the cases again and I had a new set of studs around so I replaced them to see if that helped.
I had the same idea as 190mech about using RTV on the cylinder side of the gasket on the outer ring instead of copper spray there. I thought it was probably a dumb idea, but since John said the same thing without prompting I figured maybe it wasn't so bad. Just needed to figure out how to do it.
I masked off the outer ring of one side of the gasket and then hung it up and gave it a couple of coats of copper spray before taking the tape off. I wasn't sure about residue from the tape, but I used good stuff from 3M and it seemed to be pretty clean. Not saying it is clean enough for sure, but at least it didn't appear to leave anything behind.
I gave the head a quick coat as well and then stuck the o-ring in place.
Then I masked off the outer edge of the cylinder. I ran some tape around the bore and then stuffed paper towels in to make sure nothing got on the bore and then coated the center with copper spray. Again, it looked pretty clean when unmasked.
Then I matched a base gasket to the cylinder and coated it with Ultra Grey before installing it and the cylinder. I put a light coating of Ultra Grey around the outer ring of the cylinder. So the underside of the gasket will meet up with a copper coated bore area where it is also coated and RTV on the outside edge where the gasket has no coating. The the top side of the gasket is totally copper sprayed and meets up with a cooper sprayed head and o-ring. Talk about a no-fuss installation process! I torqued the head down and no studs acted up like before.
Then I wanted to see what was up with my pressure tester losing pressure. I started by replaced the old reinforced hose with Tygon fuel line. Still lost pressure. I ended up sticking the whole rig under water and saw that about 1 tiny bubble per 1-2 seconds would come from the end of the inflation bulb when it was pumped up to the gauge's 15psi max.
Perfect, because I have a spare bulb. Or not. I searched for it and then realized that I think I gave it away not long ago assuming that I haven't needed it for this long so I won't need it. I just ordered another on eBay to hopefully be here by late next week.
Before I can even ride though, I'm gonna have to figure out what part of the ignition is failing.
