Post by 190mech on May 26, 2010 7:27:30 GMT -5
Pipe should 'hit',open class MX bikes hit real hard,wheelies when they hit!Gotta be something wrong with pipe dimensions,maybe we can find a cure...
Post by stepthrutuner on May 26, 2010 8:55:23 GMT -5
I say keep exh. exit diam. on the small side and keep a gradual out-taper to a mild initial diffuser angle. Pipe wrapping could help a bit. Got to keep that pulse energy high to make a pipe 'work'. Headpipe building is by far the most challenging task in constructing pipes.
Post by 90GTVert on May 26, 2010 10:39:31 GMT -5
I'd have a hard time building a head pipe to fit, let alone make it work. lol
Post by 90GTVert on Jun 1, 2010 11:33:36 GMT -5
Got the new cylinder head today. It was only $21.95 and it should be easier to get the squish clearance I need with it.  Other head...
Post by 2strokd on Jun 1, 2010 13:33:50 GMT -5
Purdy nice :thumb:
Post by 190mech on Jun 1, 2010 19:53:00 GMT -5
That should have most of the goodies to get T2 back smoking wont it?Its kinda like the 'flag ship' around here!!
Post by 90GTVert on Jun 1, 2010 19:57:47 GMT -5
Gotta get a new reed cage. That's in the Venus. Still need to make a cylinder spacer. I'm probably forgetting something else. I'll get back to it after the Sunl is together again I hope. Was gonna work on one today or tonight, but I've been busy watermarking pics.
Post by 190mech on Jul 3, 2010 6:06:15 GMT -5
Any news on T2?What size cylinder spacer do you need?
Post by 90GTVert on Jul 3, 2010 10:28:43 GMT -5
No news. I haven't touched it. Belt troubles with 2 scooters and getting ready to start working on my Mustang have got me pretty broke. Since I know I don't wanna spend the money to get the stuff it needs to run, I just haven't touched it. Essentially I have 5 projects (4 scooters and a car) and I can't really keep up with them all too well. I might be better off to sell a couple of scooters sometime. I thought having 4 scoots would mean I'd have 'em around for friends to ride and stuff. It turns out that it gets to be too much money for my budget to keep them all running well and tinker with different things. I could stop tinkering, but them I would be bored with them so ...  Sorry, I will get back to it at some point.
Post by 90GTVert on Dec 1, 2010 17:53:25 GMT -5
I decided to finally open up the ZX like I said I'd do some time ago. As you can see here, it's about 21mm at the header because of this gasket holder. I'm going to remove it and use flat gaskets instead. A bit more of a pain to install, but it'll open the header up quite a bit.  After trying to chisel out the piece, I discovered it was welded all the way around and chiseling it out wasn't a good option. I cut the flange off and worked on it that way instead. Here's the pipe side. What was left there popped out easily.  Here's the mess I made of the flange side with a chisel.  I ground that out and ended up with a 26mm flange, up 5mm from before.  I decided not to weld it back together until I match up the cylinder. This pic illustarates why that's a good idea in this case.
Post by 190mech on Dec 2, 2010 5:24:58 GMT -5
Looks like its flange building time!!
Post by 90GTVert on Dec 2, 2010 6:37:23 GMT -5
I actually think if I elongate the slot for the bolt on the right side of that pic, and probably grind that weld beside it for the shield just a little, it will fit way better. I wouldn't mind a 1/4" flange so it's sturdier, and this one is cracked, but I dunno if I'll do it. By the time I buy 1/4" steel and 1" tubing, I dunno if it'll be worth the money and effort with my metal tools. I'm guessing it would end up being about $30 in materials, prob plus shipping for the tubing casue I can't get that local. Only thing I might be able to get loacl would be 1" schedule 40 metal tubing, but that's actually 27.6mm ID according to specs I've seen.
Post by 190mech on Dec 2, 2010 10:17:08 GMT -5
If you slot the flange holes,tack a washer on with it aligned on the port,that way it'll always be lined up Tubing is EVERYWHERE!,go saw a leg off the lawn chair,swing set,mower handle,etc.EMT conduit is a possibility too,carry those calipers with you to the hardware store!
Post by 90GTVert on Dec 2, 2010 10:30:56 GMT -5
I need my mowers and chairs, but I'm starting to feel sorry for your wife. Just can't have nice things when you are building pipes. lmao
Post by 190mech on Dec 2, 2010 12:17:04 GMT -5
A 3 legged chair works perfectly fine! ;D
