Triton
Mar 18, 2011 15:50:08 GMT -5
Post by Reign on Mar 18, 2011 15:50:08 GMT -5
I could reeeeeeeally use a lead on those needle jets. Treatland seems to have removed all references of 6mm main jets, and they have no needle jets. The part number from Dello is 15500. If I'm reading the stock jet correctly, I think it says 27.5 and if I'm reading the recommended jetting list right, most people are running in the 50 and 60 range I contacted Provoscooter, who said it's a special order item from Malossi for them. They want $7 per jet, and they cant guarantee delivery before TNG. Any help you guys can give would be extremely appreciated! For more reference, Provoscooter said they can only get these sizes: 35, 36, 38, 40, 45, 50. I'd honestly like all of them, but if it prove to be too expensive, just the main numbers.
Triton
Mar 18, 2011 15:53:39 GMT -5
Post by shakerdriver on Mar 18, 2011 15:53:39 GMT -5
Check with Enviromoto for 6mm mains.
Triton
Mar 18, 2011 16:05:35 GMT -5
Post by 90GTVert on Mar 18, 2011 16:05:35 GMT -5
Triton
Mar 18, 2011 16:07:52 GMT -5
Post by 2strokd on Mar 18, 2011 16:07:52 GMT -5
Needle jets? Do you mean pilots or low-speed jets? If so a 27 might be fine with a airbox. I think mine is a 35,40 with an open filter. I got pilots from SIP
Triton
Mar 18, 2011 16:13:12 GMT -5
Post by Reign on Mar 18, 2011 16:13:12 GMT -5
This crisis may be averted! I took apart one of my spare stock Mikuni carbs, and pulled the jet. This PHVB uses the EXACT same pilot/idle/whateveryoucallit jet as the stock Mikuni. Now I just need a cheap place for Mikuni jets Brent: That link doesnt work for me. It keeps giving me a "Bad Gateway (Invalid Verb)" error. I've checked out SIP, but they won't ship to me unless my cart is over $100. Also, I don't need any 6mm jets. I got a variety pack a few weeks back.
Triton
Mar 18, 2011 16:16:22 GMT -5
Post by 90GTVert on Mar 18, 2011 16:16:22 GMT -5
Triton
Mar 18, 2011 16:18:54 GMT -5
Post by Reign on Mar 18, 2011 16:18:54 GMT -5
Triton
Mar 18, 2011 16:30:29 GMT -5
Post by 90GTVert on Mar 18, 2011 16:30:29 GMT -5
I'd say that a good price for that style of jet. The odd pilots can get pricey from some sellers.
Triton
Mar 18, 2011 18:15:22 GMT -5
Post by 2strokd on Mar 18, 2011 18:15:22 GMT -5
Thats good to know about the pilots being the same between those two carbs
Triton
Mar 23, 2011 13:02:15 GMT -5
Post by Reign on Mar 23, 2011 13:02:15 GMT -5
I managed to find a site called economy-cycle that handled the jets for $3.25 a piece, $9.99 shipping. so for about $32.50 I got 7 jets. I now have the following idle jets: 22.5 27.5 30 32.5 35 37.5 40 45 50 Hopefully one of these is the right one! Not that it ends up needing a 60
Triton
Mar 23, 2011 13:45:51 GMT -5
Post by 90GTVert on Mar 23, 2011 13:45:51 GMT -5
It'll probably need a 25 or a 42.5. :tongue:
Triton
Mar 28, 2011 11:35:07 GMT -5
Post by Reign on Mar 28, 2011 11:35:07 GMT -5
[rant]
Reminder to self: Always check something before you buy a new part, and always check the part before you tear it completely apart!
So I went to throw the new throttle cable on today. It's about 25 degrees out. I get half the panels tore off to get to everything I need to, get it all disconnected, and tear it out of the scooter through the front. After about an hour of work for that, I notice that the carb end of the stock cable is actually the right end that I needed! Well, that's pretty cool, too bad I didnt check before I tore it out.
So then I feed the new cable through, hook it up to the throttle, go down to hook it up to the oil pump, and realize it's not going to work because it doesnt have the little stopper that the stock one does.
So now after an hour of working in the freezing cold, tearing everything apart... I realized that I wouldnt have had to tear anything apart at all. Just hook up the new carb and go.
So maybe if it would stop being 20 degrees and snowing/raining every single day, I would be able to actually do something other than screw up. It's nearly APRIL... WARM UP!
[/rant]
Triton
Mar 28, 2011 11:51:17 GMT -5
Post by 2strokd on Mar 28, 2011 11:51:17 GMT -5
Now, now. calm down . It will come, i promise. (Go to TNG) The weather. Im glad you figured out that you could have saved time if you would have (Go to TNG) taken the time to check the throttle cable before taking the time to(Go to TNG) order a new cable that ended up being a waste of time and money because you didnt (go to TNG) take the time to look at the set-up that was already ready for (go to TNG) your carb that you took the time to get everything you need for . Im just messin man, i know you need to be at your sister grad. :lol:
Triton
Mar 28, 2011 11:57:03 GMT -5
Post by 90GTVert on Mar 28, 2011 11:57:03 GMT -5
I feel like Robert is TryNG to tell you someThiNG.
Triton
Mar 28, 2011 12:00:10 GMT -5
Post by 2strokd on Mar 28, 2011 12:00:10 GMT -5
Who me ? Was i thinking out loud again :devil: ?
