Triton
Apr 4, 2011 19:51:42 GMT -5
Post by 90GTVert on Apr 4, 2011 19:51:42 GMT -5
Before you chunk it, I'd probably give the flat top bowl a shot. If the carb's base has a receiver groove for the o-ring style gasket, it might be a problem. If it's flat, it should seal with a rubber gasket. You could also try contacting dellortodirect.com to see if they can get a gasket for a reasonable price.
Triton
Apr 4, 2011 20:02:00 GMT -5
Post by shakerdriver on Apr 4, 2011 20:02:00 GMT -5
You know with a 9" stretch you wouldn't have any air filter clearance issues Ben. Just a thought.
Triton
Apr 4, 2011 21:12:52 GMT -5
Post by Reign on Apr 4, 2011 21:12:52 GMT -5
Before you chunk it, I'd probably give the flat top bowl a shot. If the carb's base has a receiver groove for the o-ring style gasket, it might be a problem. If it's flat, it should seal with a rubber gasket. You could also try contacting dellortodirect.com to see if they can get a gasket for a reasonable price. It's worth a shot, right? It's just a flat groove. It basically uses the same style of gasket as the stock Mikuni. O-ring style, but flat instead of round. I guess I'll get to work sanding it down tomorrow and see what I can come up with.
Triton
Apr 4, 2011 21:18:17 GMT -5
Post by Reign on Apr 4, 2011 21:18:17 GMT -5
You know with a 9" stretch you wouldn't have any air filter clearance issues Ben. Just a thought. As nice as it looks on your scoot, I just think it would make mine look weird
Triton
Apr 5, 2011 2:44:24 GMT -5
Post by lshigham on Apr 5, 2011 2:44:24 GMT -5
Ben, I found the float bowl for my old PHVB, do you want the whole bowl or just the gasket? You can have either/both free of charge.
Triton
Apr 5, 2011 11:36:57 GMT -5
Post by Reign on Apr 5, 2011 11:36:57 GMT -5
Ben, I found the float bowl for my old PHVB, do you want the whole bowl or just the gasket? You can have either/both free of charge. PMed :thumb: I'm wondering if this will work for my scooter? www.partsforscooters.com/145-41_spark_plug_cap
Triton
Apr 5, 2011 11:51:25 GMT -5
Post by 90GTVert on Apr 5, 2011 11:51:25 GMT -5
That cap should work.
Triton
Apr 5, 2011 11:59:09 GMT -5
Post by Reign on Apr 5, 2011 11:59:09 GMT -5
Good. I'm ordering a UNI filter from them, so I figured I should throw a few other things in the cart while I'm at it. How far can you crush a UNI down until you start losing performance from it? I figure if I get the UNI, I won't have the issue with the plastic being in the way, since it's foam.
Triton
Apr 5, 2011 12:11:33 GMT -5
Post by 90GTVert on Apr 5, 2011 12:11:33 GMT -5
Dunno. Never tried to crush a UNI. I used to have a filter for a pocketbike that was foam with a chrome top and a coil inside that was actually meant to be collapsible. Wish I knew where to get one again.
Triton
Apr 5, 2011 12:25:27 GMT -5
Post by Reign on Apr 5, 2011 12:25:27 GMT -5
I guess I'll find out how easily they crush when I get it! It won't have to crush very much, anyways. Just enough to get past that V in the plastic.
Triton
Apr 5, 2011 12:32:32 GMT -5
Post by drawkward on Apr 5, 2011 12:32:32 GMT -5
I have a UNI foam filter. It's hollow with a large coil inside. Crushes and returns to it's regular shape. Worked great attaching it directly to my carb and having it pressed to the frame. Over time it's going to wear down much faster (mine is starting to feel pretty weak where the foam connects to the rubber coupler).
I wouldn't worry about airflow restrictions from that... The amount of flow lost is going to be pretty insignificant. Just jet it with it crushed (obviously).
Triton
Apr 5, 2011 12:46:12 GMT -5
Post by Reign on Apr 5, 2011 12:46:12 GMT -5
I have a UNI foam filter. It's hollow with a large coil inside. Crushes and returns to it's regular shape. Worked great attaching it directly to my carb and having it pressed to the frame. Over time it's going to wear down much faster (mine is starting to feel pretty weak where the foam connects to the rubber coupler). I wouldn't worry about airflow restrictions from that... The amount of flow lost is going to be pretty insignificant. Just jet it with it crushed (obviously). Thanks for the input. Seems like my luck might be turning around! Hopefully this PHVB bowl works out too, and I should be set.
Triton
Apr 6, 2011 7:39:12 GMT -5
Post by lshigham on Apr 6, 2011 7:39:12 GMT -5
Triton
Apr 6, 2011 8:27:11 GMT -5
Post by Reign on Apr 6, 2011 8:27:11 GMT -5
That's the one! How much do you want for it?
Triton
Apr 6, 2011 8:44:02 GMT -5
Post by lshigham on Apr 6, 2011 8:44:02 GMT -5
That's the one! How much do you want for it? Nowt, PM me your address and I'll drop it in the post My 500th post ;D
