Post by sirironduke on May 23, 2014 22:15:20 GMT -5
Got any recomendations on jackets or coats for riding in the heat? Its spring and i cant ride with my thick carheart anymore.
Post by 90GTVert on May 23, 2014 22:35:36 GMT -5
Mesh. I don't have a problem wearing a mesh jacket when it's hot out and they're better that just a tshirt should you crash. I wear mesh back gloves with leather palms too. Not the greatest protection, but at least they're cool.
I've got a Joe Rocket Ballistic jacket that I found on closeout years ago. It's got a thick removable liner. Then it's got zippered sections on the front, back, and arms that have mesh behind them so you can adjust how much air you want. With the combination of liner and mesh I wear that anywhere from the coldest I ride (below freezing, though with the aid of a flannel under it) up to about 80F nights or 70 in the daytime. Hotter than that and I get the mesh jacket out.
Post by sirironduke on Jun 5, 2014 4:37:22 GMT -5
Brent, after my second light failed i desided to take them apart, and i figured out the issue. the LEDs are getting too hot and coming unsoldered. a simple fix for me, but im good at stuff like that. it may be why they kept falling out of your holder. my suggestion is to look for something different.
Post by 508scoot on Jun 18, 2014 23:44:14 GMT -5
hi guys I'm new here just wondering if you know how to lower the forks on this scooter or if it is even possible. 90GTVert , i have the same exact taotao ATM50 at u any help would be much appreciated . thanks
Post by scooterpimp on Jun 19, 2014 0:26:12 GMT -5
hi guys I'm new here just wondering if you know how to lower the forks on this scooter or if it is even possible. 90GTVert , i have the same exact taotao ATM50 at u any help would be much appreciated . thanks When u say lower the forks, are you refering to lowering front end? If so fork tubes can be slid up & reclamped , but fender etc. May be effected. Look under front fender to see what i trying to explain. Hope this helped ?
Post by 90GTVert on Jun 19, 2014 4:27:37 GMT -5
Post by 508scoot on Jun 19, 2014 22:44:59 GMT -5
hi guys I'm new here just wondering if you know how to lower the forks on this scooter or if it is even possible. 90GTVert , i have the same exact taotao ATM50 at u any help would be much appreciated . thanks When u say lower the forks, are you refering to lowering front end? If so fork tubes can be slid up & reclamped , but fender etc. May be effected. Look under front fender to see what i trying to explain. Hope this helped ? this was helpfull i will post a pic tommorow thanks
Post by 508scoot on Jun 20, 2014 14:09:35 GMT -5
When u say lower the forks, are you refering to lowering front end? If so fork tubes can be slid up & reclamped , but fender etc. May be effected. Look under front fender to see what i trying to explain. Hope this helped ? this was helpfull i will post a pic tommorow thanks ok so this is the pic i believe i just need to open up the two bolt on each side and slide the forks up correct. ![](//storage.proboards.com/2855264/thumbnailer/cJ9IjiouPhxwmnam8rFz.jpg)
Post by scooterpimp on Jun 20, 2014 14:38:04 GMT -5
this was helpfull i will post a pic tommorow thanks ok so this is the pic i believe i just need to open up the two bolt on each side and slide the forks up correct. Yup.
Post by 508scoot on Jun 20, 2014 23:07:56 GMT -5
ok so this is the pic i believe i just need to open up the two bolt on each side and slide the forks up correct. Yup. Dont mind the state of the scooter in the process of repainting all my panels and replacing the carb , exhaust, and upgrading to 100cc
Post by scooterpimp on Jun 20, 2014 23:14:31 GMT -5
Dont mind the state of the scooter in the process of repainting all my panels and replacing the carb , exhaust, and upgrading to 100cc Work In progress .Pimp dont judge! Keep us posted as you progress.
Post by 508scoot on Jun 20, 2014 23:16:06 GMT -5
i will how do i open up a thread on this forum ill open one up with all my work
Post by 90GTVert on Jun 21, 2014 10:27:57 GMT -5
You should see a "Create Thread" link near the top right of the section you wish to create a thread in. On that right side you should have the forum logo, then date at the right of the menu bar, Participated button below that, and then Create Thread below that in the section title bar. If you're in an existing thread there will be a Reply button in that spot instead.
Post by 508scoot on Jul 3, 2014 23:45:56 GMT -5
hey guys question my scooter i upgraded it to 100 cc i notice that the battery i bought for it before i upgraded it a week after is draining fast, and not recharging enough so iv been having to get a jump start every now and then should i get a bigger battery do to the engine needing more power to kick over now and if so waht size
Post by 90GTVert on Jul 4, 2014 6:29:15 GMT -5
Check your voltage at the batt when the scoot is running. Could be a charging issue. Rev it up and hopefully it'll hit close to 15V. With the battery fully charged you can check resting voltage and then check cranking voltage. Hopefully 12.5+ at rest and even cranking the engine over should be 9.5V+. If you do replace the battery consider lithium ion. They cost a bit more but have lots of cranking amps. Motobatt makes batts with a bit more CCA as well. If there's tons of extra room in your battery tray you may be able to go bigger with the batt. Some companies cheap out and put a smaller one in stock.
