Post by supermel74 on May 12, 2010 18:43:58 GMT -5
First post on this board but I've been reading it for awhile. Tons of great info here. Anyways, I added a Leo Vince TT exhaust plus yellow Leo Vince clutch springs and 4.3 gram weights. Before that, I was getting 47 mph top end. Now I'm getting around 41-42. My rpms went up from 7000 to 8000 and I'm keeping slightly better speed uphill than before but I can't afford to lose any top end. I was actually hoping to gain 3-5 mph but instead lost 5. Do I need heavier weights? If so, does anybody have a good rough estimate of what weight might work best the first time and a good place to buy? The scoot is an Adly with minarelli engine. Thanks.
Post by 90GTVert on May 12, 2010 19:05:36 GMT -5
:welcome:
You might wanna try your stock weights again, or are the 4.3s the stock weights? If you haven't already, I would suggest checking your spark plug after a WOT run to make sure you aren't running lean.
Post by supermel74 on May 12, 2010 19:13:21 GMT -5
Thanks. The 4.3 weights are what came with the pipe. I was thinking about putting the stock weights in and seeing what that does. I weighed them, probably not very accurately, and they seem to be around 7g. I'll have to break down and buy an impact wrench though. I had someone else put them in along with the springs. It seemed like it wanted to go but was being held back... Edit: impact wrench has been ordered. www.harborfreight.com/1-2-half-inch-electric-impact-wrench-45252.html
Post by 190mech on May 12, 2010 19:28:46 GMT -5
Ya may need to do some carb tuning after a pipe installation also..
Post by 90GTVert on May 12, 2010 19:36:17 GMT -5
Don't forget that you can also combine weights to get a different result. If you use 3 4.3g and 3 7g weights staggered you can see what the result would be with 5.65g rollers.
Post by supermel74 on May 12, 2010 19:38:28 GMT -5
Ya may need to do some carb tuning after a pipe installation also.. I'm hoping not to have to because I'm a complete noob to all of this. I probably should have just stuck with the stock exhaust and left well enough alone.
Post by supermel74 on May 12, 2010 19:42:48 GMT -5
Don't forget that you can also combine weights to get a different result. If you use 3 4.3g and 3 7g weights staggered you can see what the result would be with 5.65g rollers. Yeah, that gives a few more options in weight to try. Is it ok to leave 2 different sets of weights in or should they eventually be switched to all of the average weight?
Post by 90GTVert on May 12, 2010 20:49:04 GMT -5
It's important to check the tune because a lean spot can damage the engine. Start by making a pass at WOT and shutting off the ignition. You can't get a perfect read like a vehicle with a manual clutch, but if you brake the engine will die pretty quickly. Remove the spark plug and see if it indicates rich or lean.
It's OK to leave 2 different weights in.
Post by supermel74 on May 12, 2010 21:12:43 GMT -5
OK good to know. I"ll give that a whirl tomorrow. I'll take a pic of the plug too to get a more knowledgeable opinion than mine. :stumped:
Post by supermel74 on May 13, 2010 11:26:42 GMT -5
Start by making a pass at WOT and shutting off the ignition. . I rev it to wot with the scoot on the center stand right?
Post by 90GTVert on May 13, 2010 11:44:56 GMT -5
Take it down the road so it's under load. Of course be safe and don't get a ticket.
Post by supermel74 on May 13, 2010 12:08:26 GMT -5
Ok, I need to drive it to where I can mess with it anyways. Not sure if I can bring it in without braking though, lol
Post by 90GTVert on May 13, 2010 12:39:57 GMT -5
Actually you need to brake for better results. WOT, hit the kill switch, brake quickly so the engine stops, check the plug.
Post by supermel74 on May 13, 2010 12:52:30 GMT -5
Ok thanks. I'll find a road out in the country where I can pull this off properly
Post by 90GTVert on May 13, 2010 13:36:35 GMT -5
I know it can be a bit of a pain, depending on your location, but it's worth it to know if your jetting is safe or not.
