Post by moofus02 on Oct 28, 2013 13:52:55 GMT -5
The length of the hammer handle lol
Post by waltinhawaii on Oct 28, 2013 14:02:08 GMT -5
nice try moofus, but the aviation snips are still up for grabs!
Post by ryan on Oct 28, 2013 15:07:34 GMT -5
ill guess for proper weight distribution
Post by waltinhawaii on Oct 28, 2013 17:10:18 GMT -5
Interesting theory Ryan! Nope, c'mon you greenhorns, get in a guess. It's monday and too much work to do anyway and I hate working
Post by ryan on Oct 28, 2013 18:30:08 GMT -5
we get one guess a day right?
liftit
Post by liftit on Oct 28, 2013 20:42:44 GMT -5
As someone who spent three years laying rail for the Alaska Railroad, I should know this.
I'm assuming you mean rails, and the reason for that width has many myths. But the reason US rails are that far apart is because England's were. Many stories about it being the standard width of carriages and chariots and whatnot, but it's mainly an arbitrary number.
Post by waltinhawaii on Oct 28, 2013 21:45:34 GMT -5
Liftit, that's pretty much it! The number is not exactly arbitrary, but that's close enough. England built the first rails and equipment, and the US took the market over after that so we built them same way they did so the machines could be used interchangeably. England did so because the early trams were built that way. And the trams were built that way to use the same roads that Rome had initially built. The Romans used that measurement, it was said, because they needed to fit 2 horses side by side for their chariots so if you wanted to build roads of different width, you could; but the wheels would eventually break from bucking too much crud outside of the 'normal' roman road width. So, pretty much arbitrary and just a custom that was handed to folks that had too much inertia in use to make a fuss over it. In the early days I could see people following the tradition as the wheel spacing needed to follow the road widths to prevent too much breakage, but in these days, it's just too expensive to move the width as we cannot back date the equipment that has to run on them.
PM me your address, sir! the prize is yours (no big deal, just a pair of souped up scissors).
liftit
Post by liftit on Oct 28, 2013 22:20:47 GMT -5
Haha, I honestly just wanted to answer a question about rail.
Post by waltinhawaii on Oct 30, 2013 5:12:25 GMT -5
Post by 190mech on Oct 30, 2013 9:12:39 GMT -5
Thats an inner sound deadner,the LeoVince pipes use a similar set up,surely it messes with the pipes tuning though!
Post by 2strokd on Oct 30, 2013 12:49:36 GMT -5
Never knew TG did this as well. Thanks for sharing this.
Also explains why they are a quieter pipe in comparison.
jonik
Post by jonik on Oct 31, 2013 9:24:22 GMT -5
Yasuni has that also.
Post by 2strokd on Oct 31, 2013 10:52:08 GMT -5
Boooo! What Yasuni model is that?
jonik
Post by jonik on Oct 31, 2013 13:41:28 GMT -5
C16.
Post by 2strokd on Nov 1, 2013 7:42:34 GMT -5
What a shame..
