peterbeater
La Prieta is coming along slowly, but nicely :)
Post by peterbeater on Sept 15, 2013 12:34:06 GMT -5
the scoot is coming along nicely. wish i had more time and money to work on mine like this... ill keep following this thread to see your progree. keep up the good work
Post by vesurka on Sept 18, 2013 16:11:13 GMT -5
Post by 90GTVert on Sept 20, 2013 11:05:07 GMT -5
Sorry some of the mods didn't work out, but it looks good. Clean.
Post by vesurka on Oct 7, 2013 0:57:16 GMT -5
Post by 90GTVert on Oct 7, 2013 4:39:49 GMT -5
How many watts is each light?
Post by vesurka on Oct 7, 2013 9:27:54 GMT -5
Post by 90GTVert on Oct 7, 2013 9:33:55 GMT -5
Keep check on your battery voltage with 100W of light. Never tried running that much for any length of time, but you may find you need to keep it on a charger when not in use, because I don't know that the scoot will keep up with the draw.
Search for downhill bars, and you'll need an adapter for the bars. RacingPlanetUSA carries them as well as a lot of overseas sellers like Scooter Attack and SIPScooterShop.
Post by vesurka on Oct 7, 2013 10:00:12 GMT -5
Thanks, Brent. I will keep check on the battery. I had the same thoughts as you about keep it charged, but i rarely ride at night and i have them off while riding in the day so they aren't used much. Still, they need to be reliable when i actually DO need them. I will try some night rides tonight and see how everything holds up. Thanks
Post by vesurka on Oct 7, 2013 13:39:27 GMT -5
Battery came in, works great! seems to stay charged with the headlights on as well. Accidentally hooked the terminals up wrong the first time... was too excited to get it on, and blew the fuse
Post by vesurka on Oct 12, 2013 12:57:49 GMT -5
Installed a tach, worked well with the tabs that were used to hold the stock cluster/headlight. Ordered a matching speedometer that will go on the other tab beside the tach.
Post by 90GTVert on Oct 12, 2013 13:18:15 GMT -5
Looks good there.
Post by 70ccsuperyates on Oct 12, 2013 13:21:51 GMT -5
I wish my controls were in their own housing mine were made in the handle bar covers and can't be taken out either
Post by ryan on Oct 12, 2013 21:27:52 GMT -5
keep me posted about the tach, i bought one earlier this week and am trying to figure it out
Post by vesurka on Oct 12, 2013 22:32:44 GMT -5
this tach had 2 sets of power/ground wires. 1 set for the illumination and the other set for the actual gauge power. the last wire went into the coil positive.
Post by ryan on Oct 12, 2013 22:52:14 GMT -5
can you tell me specifically what colors go where it would really help me alot!
