Post by dan50 on May 19, 2017 22:59:45 GMT -5
I found out that the Jog90 longcase engine is plug & play. No modifications to existing wiring harness. Just add carb, mount it in (same mounts as 1E40QMB), start it up and adjust the carb. I'm sure I'll have to tune the CVT. Engine is completely assembled including the variator, clutch assembly and belt). Just add carb. Just make sure you adjust the intake & exhaust valves!!
Post by dan50 on Jun 27, 2017 23:12:37 GMT -5
I'm going to start this build soon.
Installing a Jog90 engine on it.
I need a recommendation for a carb. I think a 24mm is the size I need. Also where do I start with what size jets.
It comes from Scrappydogs with a complete CVT and 10.25:1 gears. I'll be doing some CVT tuning with a Malossi multivar.
Post by 'O'Verse on Jun 28, 2017 6:52:44 GMT -5
21mm Dellorto. PHBG. 94-96 main jet.
Post by dan50 on Jun 28, 2017 23:58:10 GMT -5
Thanks 'O'Verse. The carb is the only thing that didn't come with the Jog90 engine.
Post by greggkinney on Jul 2, 2017 21:27:11 GMT -5
you got this project started yet? iv been watching out for it to take flight
Post by dan50 on Jul 3, 2017 1:14:47 GMT -5
Soon. I'm finishing up my Dongfang 4t build, then starting on the Jog90. Shouldn't take as much time because the Jog90 engine is plug & play. The LED lights I've already received. I have a set of 12" rims to put on.
I just need to order the carb & tires.
After I'll do some CVT tuning with a Malossi Multivar.
Post by greggkinney on Jul 10, 2017 20:27:48 GMT -5
any mods to the motor mounts or direct bolt on?
Post by greggkinney on Jul 10, 2017 20:30:28 GMT -5
oops lol as i read back through i seen you said it uses the same mounts.... how sweet is that!?!?
Post by dan50 on Jul 11, 2017 0:00:24 GMT -5
oops lol as i read back through i seen you said it uses the same mounts.... how sweet is that!?!? The Jog90 is plug & play. Engine is complete including the CVT, 10.25:1 gears, all I need is the carb. I already have 12" wheels for it.
