Post by 2strokd on Mar 20, 2014 10:13:17 GMT -5
I have done a little research on the Technigas and it looks like it has padding inside of the walls scooterforum.net/threads/tecnigas-next-r-padding-in-exhaust-pics.143758/ Are you sure yours does tho? Either way i wouldn't cut open to see if it is a new real 100cc pipe. Should be good..
Post by nelson on Mar 24, 2014 11:39:36 GMT -5
I hear there is an adapter that adapt a big carb to stock are box? Otherwise I will have to make something
Post by moofus02 on Mar 24, 2014 12:26:54 GMT -5
Brent had a modded airbox in one of his threads for a big carb. Project 90 I think
Post by 90GTVert on Mar 24, 2014 12:42:53 GMT -5
Post by nelson on Mar 25, 2014 7:13:25 GMT -5
I saw that and considered it, I have some old above ground swimming pool parts. just have to get it mounted under the body
Post by nelson on Mar 25, 2014 14:24:10 GMT -5
here are measurements of carb on the filter intake side od is 44mm/id is 39mm on with that connects to the intake the od is 30 and ID is 23mm
Post by nelson on Mar 25, 2014 22:41:40 GMT -5
So my flat slide mik carb is a 23-24mm. How do you think it will run? I am thinking about trading it. What say you? It fits in my polini intake but will a 21mm fit? also, do you think this head will work on a 52mm bore? Thanks guys m.ebay.com/itm/181285641306?nav=SEARCH
Post by nelson on Mar 25, 2014 22:42:17 GMT -5
Post by Sitticuss on Mar 26, 2014 0:37:36 GMT -5
Isn't that a non squish head. Like the one it comes with? If thats what your looking for I'd send you my old one.
Post by moofus02 on Mar 26, 2014 1:09:52 GMT -5
Isn't that a non squish head. Like the one it comes with? If thats what your looking for I'd send you my old one. If you blow the pic up it's a stock head with the donut ring Sent from my SPH-L720 using proboards
Post by 90GTVert on Mar 26, 2014 6:19:02 GMT -5
A 23-24mm should work fine. 21mm Dell is the easy way to have a larger than stock carb though since it fits the stock intake and airbox, at least on clones. Polini intake is longer and will stick the carb farther out. You need that with some larger carbs, but not with a PHBG.
Post by aeroxbud on Mar 26, 2014 6:44:05 GMT -5
Post by nelson on Mar 26, 2014 7:15:13 GMT -5
nice pipe for sure, what does it have to do with thread The nearest sound I have heard to that from a scooter pipe is the PM Tuning 360 pipe I had on my Rox. It is built like a folded back MX pipe with a big expansion pipe.
Post by nelson on Mar 26, 2014 7:19:16 GMT -5
well, i guess i will just try and run the 23mm flat slide that i have right now that came with the scoot. I dont know how this will work out once i put the plastics on though. I guess what i will end up doing is switching engines. I will put my 70 in the complete stock looking scoot and the 90 in my almost stock looking scoot. Then i will have room to add an air box some place on the frame like Brents. Does any know about old mikuni/sudco carbs? I know a sudco prepped mikuni is a great carb for quads so i assume it will work good on my scoot. A 23-24mm should work fine. 21mm Dell is the easy way to have a larger than stock carb though since it fits the stock intake and airbox, at least on clones. Polini intake is longer and will stick the carb farther out. You need that with some larger carbs, but not with a PHBG.
Post by nelson on Mar 26, 2014 9:28:06 GMT -5
my pipe has shipped from overseas and my rim is in the mail! shouldnt be long now and this baby will come to LIFE!!! it has been an interesting experience to say the least!I only have $350 out of pocket into this bike so far!( i got the hoca 43.5 crank for free pretty much by taking online test $150) Not bad! i had a guy at the gas station ask where he could get one, i tols him good luck!
