Post by Upgrayedd on Mar 18, 2014 0:09:51 GMT -5
03/07/14 - Picked up my new TaoTao CY50-T3 Scooter, still in crate.
Got it home, did a PDI on it and upgraded some things. Most of my upgrades were in line with what others here have done:
* Picked up scooter and brought it home. Unpacked from crate.
* Removed license plate bracket. Removed several stickers. Removed 'TaoTao 50' logos from both sides.
* Replaced main fuse with Bussman inline ATM fuse holder and 15A fuse.
* Adjusted Kickstarter.
* Installed new fuel filter, fuel shutoff valve, all new fuel lines and vacuum lines.
* Drained, flushed & filled forks with Valvoline ATF+4.
* Mounted front wheel, fender, front end plastics. Greased axle, speedo cable.
* Installed Prima magnetic drain plug set in rear end, and both in engine.
* Drained factory engine oil. Filled with Rotella T 15W40 oil.
* Drained factory final drive gear oil. Filled with Valvoline conventional 75W90 gear oil.
* Drained factory brake fluid. Filled with Valvoline Dot 3/4 Brake Fluid. Adjusted front ABS brake bottle.
* Opened airbox, checked and tightened all connections, removed assembly tags, verified integrity of air filter.
* Carburetor: Drilled out cap over fuel enrichment needle. Removed all headless/soft screws, Replaced with stainless steel screws + lock washers.
* Removed fuel enrichment needle. Dremeled the back end flat and slotted it for a flathead. Reinstalled.
* Installed new washers and nuts on intake and exhaust manifolds.
* Installed battery in scooter. Padded and zip tied battery in place to prevent vibration.
* Installed NGK Iridium spark plug.
* Removed CVT Cover. Cleaned out old gasket, cleaned up CVT. verified no restriction washer. Reinstalled cover.
* Modded Pickup for timing advance. Reassembled with timing set to stock, but can now be easily advanced.
* Relocated all hoses, wires, and lines up behind both side panels of scooter.
* Removed license plate light. Moved reflector up. Plugged 3 holes below that with black plugs. Put screws with black plastic washers in plate holes.
* Used dremel to clean up rough spots and bumps on all plastics up and inside of back fender.
03/17/14 - Started scooter for first time, adjusted idle fuel mixtue. went for a ride.
All things considered, things were good on the first ride. The scooter started right up in under a second. I let it warm up for about 5 minutes then adjusted the idle fuel mixture. I spent some time running the engine up and down through the rpm ranges, varying RPMs. The scooter runs decent. On a short downhill section after a flat, the stock speedo quickly went to 40mph (I suspect its off somewhere around 10% as most bikes are) and it would have gone faster but I didn't want to on the first trip out. I think I may be having some similar issues as 90GTVert had with his TaoTao in the beginning.. a bit of sputtering when rolling on the throttle, Some weird spots in the throttle.
Where I'm at now:
Intake, exhaust, and jetting is all stock.
I am going to order a tachometer for tuning.
My biggest issue at the moment is getting more power for hills. Going up any hills other than a tiny one with a full speed running start, the scooter is just a Dog. I have one hill I have to climb on the road I live on, its not a long hill but has just enough incline that the scooter barely makes it up it. Another hill in town is not much incline, the scooter slows further and further all the way up it til its dropping below 20, and RPMs are very low.
This is what I need to get figured out.
Where I'm at now:
