Post by 2TDave on May 17, 2014 7:22:00 GMT -5
Excellent. I'm fitting my bars and using a Trek bike lever for the rear temporarily. Tied the rear brake switch to the front for now.
Post by scoobnz on May 27, 2014 2:36:41 GMT -5
Post by moofus02 on May 27, 2014 2:52:58 GMT -5
Nice
Post by Lucass2T on May 27, 2014 5:29:08 GMT -5
The cost was a little expensive (280USD) but that was for the Forks,Disc,Caliper and Mount. It also comes with a new axle and spacers. So if i understand right, all those parts are $280 together? nice build btw!
Post by 2TDave on May 27, 2014 5:31:03 GMT -5
Nice work! I plan on placing an order later this week with the contact you have me. Thanks! Great build!
Post by 2strokd on May 27, 2014 7:39:33 GMT -5
Very nice build! I really like the time and effort into the airbox. So many do not realize the benefits to having one. Some of the factory ones could be placed better though. Yours is nice!
Post by scoobnz on May 28, 2014 3:14:00 GMT -5
The cost was a little expensive (280USD) but that was for the Forks,Disc,Caliper and Mount. It also comes with a new axle and spacers. So if i understand right, all those parts are $280 together? nice build btw! Yes, the whole front end including forks,calliper,disc and mounts was 280 inc shipping
Post by Lucass2T on May 28, 2014 15:51:53 GMT -5
Yes, the whole front end including forks,calliper,disc and mounts was 280 inc shipping Wow, that's a really good price! Can you hook us up with the seller? In the near future im gonna need a serious suspension upgrade for the axis...it's so wobbly in corners that otherwise sooner or later im gonna end up in a ditch... In europe the only upgrades known or the ones you would think of are the paioli RS24 or FS32 forks....and those are just ridiculously expensive.
Post by moofus02 on May 28, 2014 17:14:33 GMT -5
I got lucky and scored a set of stage 6 forks for less than half price but that is really good with the brakes
Post by Suprtigr on May 29, 2014 0:01:59 GMT -5
Hey scoobnz, where could I get that digital cluster? Also, does it take input from the speedo cable? Thanks in advance and man is this a nice build!
Post by scoobnz on May 29, 2014 0:24:05 GMT -5
Yes, the whole front end including forks,calliper,disc and mounts was 280 inc shipping Wow, that's a really good price! Can you hook us up with the seller? In the near future im gonna need a serious suspension upgrade for the axis...it's so wobbly in corners that otherwise sooner or later im gonna end up in a ditch... In europe the only upgrades known or the ones you would think of are the paioli RS24 or FS32 forks....and those are just ridiculously expensive. I sent you a PM with his details, he has lots of parts so enjoy
Post by scoobnz on May 29, 2014 0:26:00 GMT -5
Hey scoobnz, where could I get that digital cluster? Also, does it take input from the speedo cable? Thanks in advance and man is this a nice build! Sent you a PM with some details, it has a pick up and magnet arrangement which works well. It's programable for tire size so it's also accurate. Works with 2T and 4T engines
Post by scoobnz on May 29, 2014 0:34:24 GMT -5
Here are some pictures from under the hood you can see the airbox neatly tucked away and the 2 intakes at the top. I moved the ignition coil so the lead could be as short as possible. You can also see the 24mm keihin PE carb I switched to, as the pwk was waaaay to snatchy at small throttle openings, the round slide is super smooth and a dream to jet. Ended up with a 135 main jet. Here is the carb snorkel, we can use a short pipe since the pivot is so close to the carb/engine mount the total movement up and down is less than 1 inch.
Post by 2strokd on May 29, 2014 9:16:40 GMT -5
Very nice! Now that puts the meaning into air "Box". Its the best ive seen yet! So many 2T riders dont understand the importance of the induction and slap a loud stubby little open filter right on the carb. Ive dont the same in the past, but these days i can hardly bare the sound of an un-tuned double stroke with a loud intake.
Post by joshua864 on Aug 11, 2014 12:35:20 GMT -5
Where can I find those forks at?
