Post by oldgeek on Sept 14, 2015 20:11:12 GMT -5
Since I am waiting for the piston kit to arrive from Taiwan, I decided to hone the cylinder with my brand new ball hone. So how does it look?
Post by 90GTVert on Sept 14, 2015 20:33:59 GMT -5
Post by oldgeek on Sept 22, 2015 6:20:28 GMT -5
Replacement piston kit is here, I am about to get this thing running again.
Post by oldgeek on Sept 22, 2015 20:33:16 GMT -5
Piston to cylinder clearance:
.002 feeler gauge pulls out easily .003 feeler gauge piston wont go into the bore.
Ring end gap:
1 ring = .25 1 ring = .29
Which position should the tighter ring be used in?
Post by Corrosion on Sept 22, 2015 20:47:19 GMT -5
I would put the tightest on top.
Post by Lucass2T on Sept 23, 2015 0:44:19 GMT -5
Im sorry if I understatement wrong but are you measuring piston clearance with a feeler gauge???
Post by iwiketuddlz on Sept 23, 2015 4:02:01 GMT -5
Man that crosshatch looks great!!! Nice job!!
Post by oldgeek on Sept 23, 2015 6:15:54 GMT -5
Im sorry if I understatement wrong but are you measuring piston clearance with a feeler gauge??? Yes, feeler gauges. Here is an older video from the first time I tried doing it. Some wise, old school guys around here taught me how to do it. If you don't have the tools to do it "proper" this works great!
Post by Lucass2T on Sept 23, 2015 6:42:14 GMT -5
Wow dind't knew that method! Never seen it before! Oh and sometimes my Dutch android phone wrongly corrects words...
Your honingjob looks very nice though!
Post by 2TDave on Sept 23, 2015 8:16:06 GMT -5
I had to run my big motor without a base gasket to get acceptable durations. Also had to shave the head for squish on the hola kit. Maybe add a head gasket for some added squish.
Post by oldgeek on Sept 23, 2015 10:16:30 GMT -5
I had to run my big motor without a base gasket to get acceptable durations. Also had to shave the head for squish on the hola kit. Maybe add a head gasket for some added squish. I had this one set up pretty good with a base gasket, screwed up and left it out during reassembly.
Post by Corrosion on Sept 23, 2015 19:58:06 GMT -5
That the kinda thing I do when I do stuff after working all day.... I try to do some fun stuff and I'm tired and I screw up!
Post by oldgeek on Sept 24, 2015 21:21:06 GMT -5
I didn't break out the degree wheel, but I did do some visual checks of BDC and TDC. With an average thickness base gasket this is what I got. So it looks like an average thickness base gasket and no head gasket, just using copper spray is going to be good. I am pretty sure that is what I used the first time around It aint easy holding a crank at BDC with one hand and trying to take a decent picture with the other hand. Also you might be able to see the dome of this piston was not smooth like the original one was. I don't know if it is good or bad but I smoothed it out with some diamond hones I got from HF.
Post by oldgeek on Oct 3, 2015 18:56:40 GMT -5
Since my last post, I gave everything a bath and got it ready for assembly. Today I got the motor together and fired it up for a test. It started on about the 8th kick and sounds good. Tomorrow I hope to get all the plastics back on, what a PITA they are. Forecast calls for lots of rain tomorrow again so what better to do than go to the warehouse and work on scooters.
Post by Corrosion on Oct 3, 2015 22:30:22 GMT -5
Break her in. Wot blips to build cylinder pressure, then rest it. And hit it some more. I'm a bit fussy about breakin um in. But it has worked for me. I avoid the ride it like you stole it, on iron kits. It might work on nikasil. but on Iron?
