Post by 2TDave on Jul 11, 2014 12:53:24 GMT -5
Me too! Looks like an Ape!
Post by aeroxbud on Jul 12, 2014 3:02:55 GMT -5
Pipe looks nice on there. Painting the pipe is a good idea. They do rust very quickly if used in the rain.
Post by vlatx on Jul 12, 2014 5:22:03 GMT -5
I will paint the pipe with mate black ceramic paint.
Post by vlatx on Jul 19, 2014 3:52:47 GMT -5
I adjusted the cvt with 4.2gr Malossi HT Roll,I still have to change the clutch and torque spring with Malossi white springs for best take off.the top speed now is 77km/h (48mph) without a problem.Here is some pictures from the freshly paintet pipe.
Post by TheAmishSasquatch on Jul 19, 2014 7:35:48 GMT -5
nice scoot looks like an Aprilia knock-off... and thats a good thing.
Post by vlatx on Jul 20, 2014 10:23:13 GMT -5
One more pic from today riding
Post by vlatx on Jul 24, 2014 17:43:27 GMT -5
Post by 2strokd on Jul 25, 2014 15:06:12 GMT -5
I like it man! Nice ride!
That pipe is a great lil pipe for 50cc scoots too! I had one for awhile..
Post by vlatx on Aug 14, 2014 8:06:53 GMT -5
I bought new helmet for me,It is A MT Imola Speed with black visor
Post by vlatx on Aug 18, 2014 16:34:13 GMT -5
Here are some pics from the CVT updates: The Koso Vario with 3.5gr rollers and longer roller ramps,Ф 99mm with 21mm boss. This is how i set te belt in rear pully for best take off,the belt is stock size 788 17 bando. The belt ride on the vario 5mm from top edge,i whill make some tests with longer belt to see if I can make full belt travel on the vario with 799 17 from Tensai. I also used malossi reinforced contra spring (white) because the belt whas riding in the pully before the clutch engaged,on the clutch i have malossi white clutch springs (5500rpm).The first gray one is the stock spring and the big blue one is from 125cc made by Top Racing and is very stiff. The engine is reving on 8.000 rpm when full trotle is open on acelleration and 85000 rpm at top speed of 78 kmh (48 mph) on flat road,on downhill the speed is 83 kmh (50mph).All speeds are mesured with GPS devise.
Post by 90GTVert on Aug 18, 2014 18:49:35 GMT -5
5mm is good travel for a belt that length on a 99mm pulley. I think you may need longer than 799mm to realize it's full potential on the top end, but go too long and the rear pulley can't handle it. I could put my 816 belt on with the stock rear pulley without compressing it at all and it was so loose that it was very slow moving till it took up the slack.
Post by vlatx on Aug 19, 2014 10:30:51 GMT -5
Yes too long and it will slip on take off until it can grab some grip in the pully
Post by Sitticuss on Aug 19, 2014 17:06:45 GMT -5
nice setup all around dude...
Post by bazhee on Aug 23, 2014 17:18:24 GMT -5
Awesome bike dude. Check your PM i messaged you!
Post by vlatx on Aug 24, 2014 7:26:08 GMT -5
