Post by psychedelicode on Jul 13, 2014 20:58:43 GMT -5
Plug is a nice tan. No indication of a bad mix.
Post by forde88 on Jul 14, 2014 3:39:58 GMT -5
doesnt matter how clean it is if float height is wrong
Post by forde88 on Jul 14, 2014 3:57:11 GMT -5
if you are unable to ride the bike checking your plug wont tell you anything you are just checking your idle mix
Post by 2TDave on Jul 14, 2014 5:17:11 GMT -5
If the plug is wet it will tell you your rich.
Post by psychedelicode on Jul 14, 2014 5:32:51 GMT -5
What should the float be set to?
Post by 2TDave on Jul 14, 2014 5:39:34 GMT -5
If you turn the carb upside down it should be parallel with the base. There is more on this in the tech library under carb tuning and adjustment.
Post by 90GTVert on Jul 14, 2014 5:40:33 GMT -5
Post by psychedelicode on Jul 14, 2014 10:51:53 GMT -5
Well its definitely float adj. But you can't adj this float. There is no metal tab to bend. It's all plastic. Carb is mikuni vm13.
Post by psychedelicode on Jul 14, 2014 11:23:55 GMT -5
Well instead of bending the plastic, I bent the spring. Running good now.
Post by 2TDave on Jul 14, 2014 11:56:56 GMT -5
Good to hear!
Post by psychedelicode on Jul 14, 2014 13:49:28 GMT -5
It's a dog though tops out at 38 mph on the dash. What do I first? It's my first 2 stroke, I know the 4strokes like the back of my hand. Transmission? Or cdi?
Post by psychedelicode on Jul 16, 2014 12:49:34 GMT -5
So, I need some help identifying this engine. Some say it's a 1e40qmb minerelli, some places call it a morini. Any ideas on how to tell the difference? I'd hate to order the wrong bbk.
Post by 2TDave on Jul 16, 2014 21:29:58 GMT -5
The cvt case doesn't look like any Minarelli I've ever seen. I'd say Morini.
Post by 90GTVert on Jul 17, 2014 11:53:28 GMT -5
I think it's the TGB Franco Morini engine, not a Minarelli.
Post by psychedelicode on Jul 18, 2014 17:18:24 GMT -5
Well, so much for my dreams of 103cc...lol What is the engine designation for the morini? 1e41qmb?
