Post by niz76 on Sept 11, 2014 13:47:30 GMT -5
So for the record, it seems that the longer offset of the motor mount tube should be on the CVT side of the motor. As shown in the pic above ^^^^^ on the 49cc motor on the left. I'm sure y'all already knew that lol..
Post by niz76 on Sept 11, 2014 16:27:45 GMT -5
The good news is I took the time to clean the Mikuni carb from the parts scoot and it works fine. Bonus! The 50cc is up and running- outta tune. I've got the stock vari back in with e-start and she's in bad need of CVT tuning. O well, it starts and runs good and I want to spend my time on the 90cc now so I'll deal with a slow stock ride.
Post by 2TDave on Sept 11, 2014 17:40:30 GMT -5
Isn't nice to have a motor and be able to do a swap in an hour or two and be riding.
Post by niz76 on Sept 11, 2014 19:02:42 GMT -5
Isn't nice to have a motor and be able to do a swap in an hour or two and be riding. That it is! So I've definitely made up my mind. I'm keeping this long case stocker for sure.
Post by niz76 on Sept 11, 2014 19:06:15 GMT -5
Top end looks good.. not seeing anything alarming so far- no metal chunks or flakes...
Post by 2TDave on Sept 11, 2014 19:13:04 GMT -5
I made a deal with myself that I would only borrow parts off my other motor if I had ordered a replacement first. Now I've got a third stripped down on the bench. Lol. Three motors, one scoot. Damn I need to find a retro. Of course when I do it will have a motor so that's not a big help.
Post by niz76 on Sept 11, 2014 19:27:14 GMT -5
I am just not seeing what could make this sound so bad... could it be this scrape in the pickup? Also when moving the connecting rod(?) there's no play up/down but a bit sloppy side to side. Considerably more play than the brand new crank has...
Post by niz76 on Sept 11, 2014 19:43:59 GMT -5
More evidence of things scraping at RPM. The flywheel puller from Partsforscooters didn't fit, but I used this gear puller without too much difficulty.
Post by jhobe6678 on Sept 11, 2014 19:45:05 GMT -5
I made a deal with myself that I would only borrow parts off my other motor if I had ordered a replacement first. Now I've got a third stripped down on the bench. Lol. Three motors, one scoot. Damn I need to find a retro. Of course when I do it will have a motor so that's not a big help. I've got a co-worker dropping off two scoots tomorrow, at least that's what he says now. I'll let you know what I got? No titles so I may part them.
Post by 190mech on Sept 11, 2014 19:56:49 GMT -5
Kinda looks like the right main crank bearing has slop,or the case has worn allowing the crank to wobble..Grab the crank end and give it a stout up and down free play check,should feel very little movement..
Post by niz76 on Sept 11, 2014 20:39:56 GMT -5
Kinda looks like the right main crank bearing has slop,or the case has worn allowing the crank to wobble..Grab the crank end and give it a stout up and down free play check,should feel very little movement.. Happy to say that there's no play in the bearing race's- I've found the problem.................................................................................................................................................................................................................................................................................
Post by 2TDave on Sept 11, 2014 20:42:23 GMT -5
And?
Post by niz76 on Sept 11, 2014 20:47:07 GMT -5
Post by niz76 on Sept 11, 2014 20:48:43 GMT -5
Now to do some reading and figure out how to get this all back together lol.
Post by 90GTVert on Sept 11, 2014 21:02:58 GMT -5
Yeah, that looks like it would make some noise. That flywheel looks different than what I'm used to on these engines and I wasn't even thinking about it being Adly. I suspect that puller should work on the rest of your motors unless they sent you the wrong thing. M27x1.0 LH is the typical Minarelli size. Here's some info from Doc that may be useful : 49ccscoot.proboards.com/thread/8538/matter-stator-adly-issues
