Post by treylaw on Mar 10, 2015 20:05:23 GMT -5
il try that
Post by stuckchuck on Mar 10, 2015 20:34:29 GMT -5
one other option if all else fails...if you put a big flat head, in the big intake hole of the isolator and put the screwdriver blade tip up under one side and rest it on the otherside of the hole you mite be able to get under it. work your way around alittle and dont try to get it in one try. do not use the screw driver between the part and the engine it will mess up the sealing surface. could also try a thin putty knife flat between the two and a tap and it should come right off. atleast its a cheap part
Post by treylaw on Mar 14, 2015 18:29:17 GMT -5
i got it off becuase my buget is no more than 50 bucks every to weeks thats why i did not want to buy another one though when doing the bbk instal my valve rockers are to short i need a link to bigger ones
Post by 90GTVert on Mar 14, 2015 21:31:11 GMT -5
PFS has the rockers for 69mm valves if that's what you need (part # 151-247).
Post by treylaw on Mar 15, 2015 2:59:55 GMT -5
its not the arms i think are to short its the lil bolts that go in to them are whats to short
Post by treylaw on Mar 15, 2015 21:42:38 GMT -5
so know one knows for sure if this is the part i need to spend 14 bucks at pay day for to fix this problem so can know if i got compression and have a trial run on the bbk and be unabel to buy a carb that be tuned
Post by niz76 on Mar 15, 2015 22:08:12 GMT -5
I recently worked on a girls scoot where the Previous owner had installed a BBK but the rocker arms didn't match and they had the adjustments screws in all backward since they wouldn't reach. I happened to have an extra set of rocker arms that came with a BBK and installed them. Voila perfect fit. It's the rocker arms that are too short not the adjuster screws.
Post by treylaw on Mar 16, 2015 1:23:45 GMT -5
ok then i will buy the 69mm rockers plus some intake and exhaust manifold bolts as the old ones are to far gone
Post by treylaw on Mar 17, 2015 19:49:55 GMT -5
once i get it running after new carb and tuneing im gonna up the gears parts for scooters has 3 difrent sizes of kits witch do you reconmend i do and how long will it take to break them in
Post by 90GTVert on Mar 17, 2015 20:41:27 GMT -5
42/16 would be the least aggressive of the gears, but a big change over stock. If your gears are the same as mine that would take you from about 11:1 stock to 8.5:1. May be a bit much. I'm not really sure what these 4Ts like for gearing. I'd prob consider something like the gears that Scrappy sells that would get you around 9.4:1. Someone else that's used different gears on these may have another opinion though, and I'm basing this off of the gear ratios stock in my TaoTao.
Break in is not a big deal. I'd just make sure to change the gear oil after the first 20-50 miles and prob again at 500 or so.
You will need to get the gears pressed apart and together. Just in case you didn't know they won't just drop in. Local machine shops should be able to handle that no problem if you take them the stock gear and new one.
Post by treylaw on Mar 18, 2015 19:00:01 GMT -5
well i want the most bang for my buck that being top end and accelaration and i ownly want to do this once. and what do you mean it wont just drop in i cant just bring the local machine shop the whole engine i dont have the tools for dismounting il be lucky if i find a impact wrench and 3/4th adater for my scokets that will do the job in my price range [if you can recommend me a electric one please do so 80-100 bucks is all i can spend]
Post by 90GTVert on Mar 18, 2015 22:32:03 GMT -5
The intermediate shaft/countershaft is in the middle of the gearbox and it's got 2 gears on it. One has to be pressed off so the new one can go back on. That's all you'd have to carry somewhere. Small part. Ignore the numbers (first pic I came across of one), but it's in the pic below. I think if you take a big jump in gearing you may be disappointed in the loss of acceleration, that's why I'd suggest sticking with the more conservative change. I don't have much experience with electric impacts to tell you which is good because I always use pneumatic. If no one else can give you a good recommendation a lot of times I'll get on amazon or a site that offers a lot of reviews to help me decide.
Post by treylaw on Mar 19, 2015 14:04:59 GMT -5
but what is the goal of gearing ratio do i want the highest first number and the lowest second number what is the ideal set up in most cases
Post by 90GTVert on Mar 19, 2015 14:09:39 GMT -5
It doesn't really matter what the numbers are, but what the ratio is. Primary and secondary gear ratios need to be considered together to come up with a final drive ratio. Maybe this will help? 49ccscoot.proboards.com/thread/3472/primary-secondary-final-drive-ratioI haven't had the opportunity to play with a bunch of gear ratios for these yet to be able to tell you what they like. I know there are people on this site with upgears that could offer some experience, but unfortunately they haven't chimed in yet.
Post by treylaw on Mar 19, 2015 22:56:00 GMT -5
it still dont make since calling upon gearing gurus i need your wisdom
