Post by treylaw on Jul 19, 2015 15:54:40 GMT -5
if some one has some info on a wire harnes that be grand
Post by treylaw on Jul 22, 2015 7:03:54 GMT -5
any one got a genral idea on what contra and clutch springs i should get and if i should upgrade the variiator and clutch on my 80cc bbk 139qmb
Post by 90GTVert on Jul 22, 2015 15:13:30 GMT -5
Always best to tune... have to say that. Just gonna guess at 1000RPM contra and 1500RPM clutch springs. I like the softer of the contra springs and don't feel the average build needs anything super stiff to keep the belt from slipping. Roller weight adjustment may be necessary as well. All clutches don't work the same with springs so I'm just guessing on the middle ground of the clutch springs. Aftermarket variators tend to help RPM stay in a bit more narrow range, nearer peak output, and sometimes provide more travel for more speed too. The clutch should be alright with springs.
Post by treylaw on Jul 22, 2015 17:37:07 GMT -5
well my buget to tune the cvt is gonna be 250 bucks and tools will be bought from the buget as well the buget so i cant spend 20 bucks 3-4 times on springs due to what if i do plan to buy a big verity pack of variators weghts and as for the contra springs and clutch springs will the gy6 ones fit cuase i cant find ones that clearly marketed as 139qmb parts
after the cvt is done all that will be left to do is upgradeing the gearbox then puting on a new rear tire renforceing the frame adding a second and resirve gas tank fabracateing in a turbo instaling nitrous a train horn and cb radio
Post by 90GTVert on Jul 22, 2015 17:51:17 GMT -5
If you're on a tight budget I would advise checking this out to help you save money in the roller/slider department : 49ccscoot.proboards.com/thread/1199/modding-roller-weightsIt shouldn't be too tough to find springs for a 139QMB or GY6 50. PFS, Scrappy, Ebay, Enviromoto, etc... all have them. There should be no need to spend near the $250 on CVT parts just to get in a decent state of tune. Get a 1000RPM contra spring for roughly $10, if you want just one set of clutch springs go with 1500RPM for $5-10, a variator costs $30-100 depending what you get but you should have no trouble finding one you like for $50 or less (NCY, Koso, Hoca, DLH). That'll put you at prob $50-100. Save $25 for a set of sliders perhaps after you work out some tuning with the method posted above. Put the rest into tools at that point or save it. You can never really have enough tools or money.
Post by treylaw on Jul 23, 2015 1:50:26 GMT -5
also how much torque will the impact driver i get need to have to do work on the cvt
Post by Elektrey on Jul 23, 2015 1:55:07 GMT -5
I've got a cordless impact that does 1200 lbs/ft torque and it's worked great for everything so far. some have been stubborn and needed to been hit for a while before they loosened up.
Post by treylaw on Jul 23, 2015 2:10:32 GMT -5
thank you elektrey that helps alot knowing i dont need to go all out on impact
Post by treylaw on Jul 23, 2015 3:22:02 GMT -5
well guys it seems that i will finush my build and get all the tools i need for future projects for just under 550 bucks
Post by treylaw on Jul 27, 2015 14:13:20 GMT -5
Post by treylaw on Jul 28, 2015 6:58:32 GMT -5
last time i post pics of my scooter
Post by 90GTVert on Jul 28, 2015 7:21:12 GMT -5
I'd wait on determining the exact locations of things like turbos and jet engines till you have one for mock-up.
Since you've got a huge mods list and plan to do some welding, Consider adding folding foot pegs to your list. Excellent mod that you'll appreciate every time you ride, or at least I do. ~$10-15 for folding pegs and ~$10 worth of steel to make mounts of some sort.
Post by treylaw on Jul 28, 2015 11:30:56 GMT -5
i determining the placement of the turbo and jets by thinking of the most pratical place to mount them ie the turbo near the exuast and the said jets on the sides of the frame though they will be the pulse type and it will be hard to figure out how to start the on the road or on the the fly so to speake
Post by iwiketuddlz on Jul 28, 2015 12:15:01 GMT -5
Whoop whoooo you go trey!!!! Let's see dim dare jets bo....!!!!!
Post by treylaw on Jul 28, 2015 12:18:43 GMT -5
You will as soon as I rather build the! Or buy em I need at least 2 making 35 pounds of thurst to do any good I think
