Post by Jwhood on Apr 4, 2015 15:30:26 GMT -5
Today matched gasket with case turned out pretty good also chamfered the malossi bbk and put bearings on crank,here are a few pic's of the matching process,was pleasantly surprised how close the gasket matched up to case,wasn't too much material to remove.... .... Pictures didn't turn out so good and didn't really take pics of the bearing install cause there is many vids by Brent & other ppl on how to do the hot/cold install!!Also does the bearing/crank have too sit another 24 hrs in freezer I would like to seal the cases back together today.The crank and bearings have been sitting in freezer for about 2 1/2 hrs now any one think the case will go back together now??
Post by Jwhood on Apr 4, 2015 17:32:57 GMT -5
Here is a port map for my malossi lc kit didn't get bottom of cylinder...
Post by 190mech on Apr 4, 2015 19:41:47 GMT -5
Yeah I was surprised how much material I had too remove too get it too fit,tomorrow I'm gonna match the bbk gasket up to the case so its a match and chamfer the ports on the malossi bbk,also getting a buddy too weld me radiator brackets on the frame some where and also take plastics off of scooter for repair in the near future,I just wish I would've known how much material the case had and I would've got a 45mm crank,oh well im good with what I got for now: / Your build is going nicely!Ive looked the web for TGB stroker cranks,but could find none.I see some listings for the suzuki AD100,but they are waay too wide to fit the cases..Where have you seen them offered?
Post by Jwhood on Apr 4, 2015 20:16:12 GMT -5
I was gonna buy a different brand stroker and modified it to fit in the morini engine,I've never seen any Tgb stroker cranks 190 but I do know that Tgb made a 90cc ATV called the "hornet" but can't find any info on what style motor that was in it
Post by Jwhood on Apr 5, 2015 20:02:20 GMT -5
Some more intake pictures,I had to get rid of alot of material( finally fixed the washer!!) So decided too post these close up pictures.... .......I smoothed the Jb weld out so it looks a lot better then in those pics.... ,I took about an inch & a 1/2 off this corner I have circled and an arrow pointing too it
Post by Jwhood on Apr 7, 2015 19:33:12 GMT -5
More progress tonight got the engine back together,it was a "beotch" but I got it after smashing my thumb and saying every bad word ever invented(the neighbors must of though I was murdering someone)lol here is my progress so far.... .... ... .....how loose should the crank spin? And I haven't put any 2t oil on bearings yet since I still need too put oil seals around the crank,can't wait too get it up and running!!!
Post by 190mech on Apr 7, 2015 20:28:24 GMT -5
Nice crank,,waaay better than the 'porkchop' stock stuff..Crank should spin freely,if it feels stiff,try rapping each end with a short piece of 2X4 board(please dont use a hammer as a crank can get out of true very easy..).I'm enjoying a 'off the beaten path build',hope its a screamer!
Post by Jwhood on Apr 7, 2015 21:23:03 GMT -5
Almost was a disaster but I averted it,I did the hot/cold install,I pushed crank with bearing in case and it only went 1/2 way I almost panicked but I got it loose by pushing it back out,then I tried again and was successful, then I did other side, and it did the same thing but this time the bearing slid off crank when I pulled and was stuck 1/2 way in case,so I asked my father n law how he would get it in the rest of the way he had a bearing install tool so I got the bearing in case. The side with crank in the freezer i then pulled it out and used a heat gun to heat bearing so I could slide crank in and button up case doing the cross tighten pattern to get an even tightning pattern, all is good
Post by Jwhood on Apr 8, 2015 12:02:18 GMT -5
Ok since I put crank in I was test fitting kick start but on crank shaft,the nut on Tgb be scoots are reversed tread so I can't get nut on crank shaft where can I order one for my crank,I measured but threads and there the same at 11.20 mm but the kickstart nut I have isn't going on any help?? ..Here is a pic of my left too tighten kickstart actuator nut,I need a right too tighten now with new malossi crank
Post by 90GTVert on Apr 8, 2015 12:49:25 GMT -5
I did a quick search and found someone else mentioning the same issue, but no solution other than not using the kickstart. You may want to try the same place you got the crank to see if they know or perhaps even contact Malossi USA. May even be listed under related items on a site selling the crank if you're really lucky.
Post by Jwhood on Apr 8, 2015 13:54:28 GMT -5
Yeah that blows I was trying too ditch the electric start dammit I'll look around and post my findings
Post by 190mech on Apr 8, 2015 14:12:26 GMT -5
Is tha Malossi crank right hand thread??TGB should be LH because the kick start will try to loosen a RH nut..If you just need a replacement nut,ScrappyDog can get TGB parts..
Post by Jwhood on Apr 8, 2015 14:15:58 GMT -5
One more question when I pulled the stock bearing seal they had grease packaged in bearings should I repack or just use 2t oil like "190" said??
Post by 2TDave on Apr 8, 2015 14:30:34 GMT -5
I don't pack crank bearings. I can't imagine it would stay in there at 10k+ rpms.
Post by Jwhood on Apr 8, 2015 17:05:29 GMT -5
Thanks was just double checking on the bearing grease thing so I started too put the head on and in the middle of putting rings on pistons they snapped not "1" but both snapped should I get malossi rings or just order rings from p.f.s,yeah 190 its right handed thread on the malossi crank was wondering if I can modify a right handed kickstart nut too work on the crank
